Graham22 Revell F/A-18 Hornet
Anything that flies
graham22
Post by graham22 »
thought I'd attack the 1/48 F18 from Revell
1st impression was oh dear, looks an old tool, lots of flash. Overall pretty poor
Assembled the cockpit,
Has to remove a lot of the raised details so the decals would sit well
Live long and Prosper - where does all the time go?
My Portfolio - My YouTube Channel - Airfix Club member no 610322
on the bench
Completed 2015-9,2014-23 2013-9, 2012-5 - Stash 158
Homerlovesbeer
Re: Graham22 Revell F/A-18 Hornet
Post by Homerlovesbeer »
Hopefully you'll tame this kit. I'm looking forward to the build :-)
graham22
Post by graham22 »
Restarted the F18, really don't like this kit although it's looking better now, not sure why I don't like it, just hasn't got a nice feel
Going to need quite a bit of filler
on the bench
I have a similar kit from Revell. Not as flashy as this, and nicely detailed. But I have lost some enthusiasm for it since I was trying to add in a resin cockpit. Once I get that installed then I might get some mojo back for mine.
graham22
Post by graham22 »
Cheers Gav, not much tonight, just filling some big gaps in the joins
More soon
on the bench
graham22
Post by graham22 »
Smoothed out the filler on the F18
on the bench
Homerlovesbeer
Wow she's a filler hog isn't she? I think my Revell Super Hornet will be the same.
graham22
Post by graham22 »
Cheers, yes just a bit
Some more progress tonight
on the bench
Homerlovesbeer
I'm currently filling my Revell Super Hornet 1:48. After doing my 1:72 airfix kits this thing is a real step backwards in fit.
What are you using to fill? I've been using Mr Surfacer 500
kiwigav
New Zealand
Post by kiwigav »
Nice looking kit, will check in again
:th:
Cheers Gav
graham22
Post by graham22 »
Cheers Gav
Painted the underside tonight
on the bench
graham22
Post by graham22 »
Upper surfaces painted
on the bench
Homerlovesbeer
How did you go painting the launcher rails underneath with them already attached? I thought you may have issues paiting behind the closest one to the main fuselage?
I'm deciding what to do with mine at the moment, paint them then put them on or do it as you have.
graham22
Post by graham22 »
Got in quite easily with the airbrush, lots of room so no issues
Finally got around to doing some work on the bench
F18 just a coat of clear
Ready for decals tomorrow
on the bench
Homerlovesbeer
Nice! We are at very similar stages now. What paint did you use? I use My Hobby acrylic and it sprayed like a dream!
My Super Hornet. I have only done the underside and elected to leave off some of the rails to assist in getting a good paint coverage. I painted them separately so they'll go on now.
Cheers :th:
Last edited by Homerlovesbeer on Mon Aug 10, 2015 9:54 am, edited 1 time in total.
graham22
Post by graham22 »
I'm using valligo model air paint
It's looking good
on the bench
graham22
Post by graham22 »
Monster decal session tonight on the F18
on the bench
Homerlovesbeer
looking great mate.
Guess what? I just sprayed the top of my Super Hornet.......and it's the same colour as the bottom! Grrr
I must have got paints mixed up as I've managed to paint the top colour on the bottom as well! I'm not sure if it's worth repainting as I'll lose my pre shading. Or do I simply pre shade AGAIN and re spray the correct colour on the bottom?
graham22
Post by graham22 »
Thanks
Finished the decals tonight, just need to decide if I add any weapons and light weathering - then another one complete
The upper colour looking at reference photos is very close to the lower shade, mines is a fraction dark I think but I think it looks ok
As for your dilemma, I don't pre-shade as I put too much paint on the model and it disappears so I favour post washes. But I'm sure which ever you decide it will turn out well
on the bench
graham22
Post by graham22 »
And final pics of the Revell F18
Turned out quite well
on the bench
heel
Post by heel »
Graham it turned out better than good. Awesome work!
Homerlovesbeer
Nice nob mate :th: :clap:
ollie
Post by ollie »
I have built this kit several times and to me it is not too bad of a kit. I know you have to rescribe panel lines. Please use clear red on the lights there. I wish all the best and have fun By the way the two vents on top of the fuselage need to be filled in. I use super glue and sand them smooth.
Damonkh
Post by Damonkh »
Wonderful job!!
Damon "Mad Hat Modeler"
On the Bench...
B-25 Mitchell
Liamcraven666
Post by Liamcraven666 »
A very nice bird , good job!
Hello :hi:
Return to “Aircraft”
