Sword 1:72 Fairy Gannet AEW.3
Joesdad
Post by Joesdad »
This is my entry
And here is a review of the kit...
http://www.intscalemodeller.com/viewtop ... 95#p174295
More to follow....
Tim (Ted)
British Aviation In Scale
Joesdad
Re: Sword 1:72 Fairy Gannet AEW.3
Post by Joesdad »
Here is the pilots seat and front wheel well made up...
Main gear wells parts being readied for assembly...
Which comes together like...
Tailplane, note the lack of locating pins..
Ready for primer...
TTFN
Tim (Ted)
Joesdad
Post by Joesdad »
After a black prime cote, wheel wells were treated to Lifecolors med sea grey and I've started on the props...
Cockpit gets Tamiya Nato Black, which as you know is a very dark green, well it is too me....
A bit more for the spinners..
The tiny cockpit for a rather large aircraft, dry brushed and a bit of colour...
Unfortunately (or not) we ain't gonna see a lot when the fuselage is assembled i think, we'll see....I'm a bit away from that yet
TTFN
Tim (Ted)
Joesdad
Post by Joesdad »
Wing tip nav lights... I guess that you'll know how is goes but if not......
1:72 might be a bit a small scale for me but I'm going have a go regardless. This is one a of my favorite tricks, in fact it's probirly one of the first i got to grips with on returning back a couple of years back.
Cut out where the light is going to be situated. Many modern kits have wing tip light lens as part of the clear sprue if not then you'll have to cut the wing tip out, you can also use this to replace the kit lens. You'll also need a piece of clear sprue larger than the cut out...
Next bit is straightforward, just glue the clear into the cut out. For added interest you can drill out where the light actually is behind the lens (clear part) and drop a little paint into the hole. Check your reference for colours..
When the glue has dried properly simply file, sand and buff to shine.. :th: easy and effective...
Hope this helps yer..
TTFN
Tim (Ted)
Joesdad
Post by Joesdad »
More progress...
Weights for the front. It goes without saying that the tri-cycle undercarriage means tail-sitter, I've used some solder wire (leaded), cut up and PVAed in place. I think I've used enough :think:
Button up fat boy..
Really quite tricky without proper locating lugs, you'll see in a min...
See...
It's balancing act to get the correct(ish) dihedral on both wings and tail plane...
Sometime later..
A bit of filling nothing dramatic...
And...
Staring to look like a Gannet now..
Bloody massive exhaust's...
Primer soon
TTFN
Tim (Ted)
Jack
Post by Jack »
Looks great so far, love the cockpit, keep up the good work :thumb2: :thumb2:
Tamiya 1/35 Tiger 1 mid production
Bandai AT-ST
Dragon 1/35 M4 DV
Joesdad
Post by Joesdad »
Jack wrote:Looks great so far, love the cockpit, keep up the good work :thumb2: :thumb2:
Thanks Jack I'll try, nice to have you aboard :banana:
Tim (Ted)
Joesdad
Post by Joesdad »
"Lazy sundry afternoon ah"
Canopy's on and getting prepped for primer..
Primer on and a selection of colours I'll be using...
Good stuff this MIG primer, I know some people have trouble with it but it seems fine to me. Until I can get hold the Badger Styrelnez gear, it'll do for me...
After pre-shading I'm left with this. I've got into this habit of, well... it's almost pre-mottling, modulating I guess, I find its helps to break up the top coat(s). It doesn't always work out but try and try again...
See you for some colour next..... :banana:
TTFN
Tim (Ted)
shortCummins
Post by shortCummins »
I agree about the MiG primer, I really like it :th:
great job so far :bow::
rgds
John(shortCummins)
stuart66madmodeller
Post by stuart66madmodeller »
:eeek: Shes shining up like a pretty penny mate. Interestibg to see how the build goes as i have this kit in my stash.
:welcome:
Joesdad
Post by Joesdad »
shortCummins wrote:I agree about the MiG primer, I really like it :th:
rgds
John(shortCummins)
Yeah John, it seems better than the AK even though its the same stuff..
Cheers bud :th:
stuart66madmodeller wrote::eeek: Shes shining up like a pretty penny mate. Interestibg to see how the build goes as i have this kit in my stash.
I didn't like the kit for a while but it's grown on me. There's no real fit issues it's just not a "shake and bake" kit that I'm used to, now that I'm used to how these Sword kits shape up, I'll probirly go a couple more starting with a rather lovely Jet Proverst/Strikemaster they've just released.
Cheers Stuart :th:
Tim (Ted)
Joesdad
Post by Joesdad »
Right! Paint time.
First of all we've got Mr Hobby Aquaous H74 Sky, this really is nice lovely stuff, once you get that "sweet spot" 50/50 mix...
Not much to show as I forgot to take piccies :doh: So we'll get on with some masking...
A bit more...
All ready for Akan's Extra Dark Sea Grey...
EDSG all on and de-masked..
The next day.... Cleared and ready for dec's :wall:
TTFN
Tim (Ted)
Willem
Post by Willem »
Looking cool mate. I like your pre-mottling idea and it shows through the paint nicely. Going to try that myself as I find that I'm a bit too ham-fisted when it comes to post-shading.
Lovely to see a Gannet getting built (beautiful plane in a strange kind of way). Great job.
Will
Edward R Murrow
Joesdad
Post by Joesdad »
Willem wrote:Looking cool mate. I like your pre-mottling idea and it shows through the paint nicely. Going to try that myself as I find that I'm a bit too ham-fisted when it comes to post-shading.
Cheers Will.
That's exactly why I do that pre-shade thing, no good at post-shading either....
Tim (Ted)
Joesdad
Post by Joesdad »
Decaling.... Not keen on the process, I'm not going to dwell on it, suffice to say there are on..
They actullay were really thin and I had a bit of trouble with them curling up, not only that but the instant they got wet they were ready too come off the backing paper..
Originally I was going to paint the tail plane flashes, but I couldn't get my masks right, also I'd have real trouble trying to cut out the little bee motif with anything like accuracy, so I'd didn't bother. Shame...
Ultimate dark dirt wash (old mark)...
TTFN
Tim (Ted)
Willem
Post by Willem »
Looking good Tim. Nearly there mate.
Will
Edward R Murrow
shortCummins
looking real good :th:
rgds
John(shortCummins)
CJSomerset
Post by CJSomerset »
Looking really good :clap: :clap: :clap:
I first came across the Gannet at RNAS Yeovilton. I just couldn't believe how big and ugly it was. For me, it was love at first sight :banana:
Joesdad
Post by Joesdad »
Willem wrote:Looking good Tim. Nearly there mate.
shortCummins wrote:looking real good :th:
rgds
John(shortCummins)
CJSomerset wrote:Looking really good :clap: :clap: :clap:
Thanks lads.
I totally agree CJ :th:
Tim (Ted)
Joesdad
Post by Joesdad »
All done lads. Here is the reveal link, if you fancy.... :th:
http://intscalemodeller.com/viewtopic.php?f=405&t=14000
Thanks for following
Tim (Ted)
gaz45
Post by gaz45 »
very nice work mate :thumb1:
