Evening folks;
Just an update on the build:
First, if you are going to paint a canopy. USE EXTREME CARE. I put 3 coats of Klear over the copper/smoke paint on the small canopy section after the paint had dried for 3 days, and today was day 3 for the klear. While masking off the canopy, to paint the frame, I noticed that there looks to be a small piece that has "detached" from the canopy.
I noticed it looking at the inside of the canopy. Not sure what is going to happen when I take the mask off at the end, but I will post results.....
Made good progress on the project today! The airframe is almost ready for primer, inspect for any filling that needs to be done and paint. I am looking forward to getting to the decal application. (Ha, I say that now...)
Got the tail mounted, along with the winglets on the underside.
Have the intake filling done, don't look to bad, and the nave lights mounted. this is ready to prime and paint.
As mentioned above, I masked the entire canopy and mounted the rear portion. I did find that the 2 canopy pieces don't fit tight, by any means. If you look light can be seen between the sections. This isn't going to cause any problem as I plan to pose the canopy open, the slight miss fit will not be seen. (the main canopy is taped in place for now. Will TEMP install for paint and decal work.)
Also have the burner can and exhaust prepped to paint. The inside is done in light grey with a black oil wash. I will try and get better pics of this once I have the Metal Color on and buffed out.
Well, that's it for now. Hope to spend a few nights at the bench this week. Also, I really commend the builds that are going on! Lots of excellent work/results and I am enjoying reading the posts.
Thanks for looking, and, enjoy the build...
