Dragon 6608 Tiger I Tunisian Initial
All your armour related reviews
mannloon
Post by mannloon »
[youtube]P__K1sxfqdo[/youtube]
Cyber-Hobby Tiger I Kursk
Rye Field Tiger I w/ Interior
burnie43
Re: Dragon 6608 Tiger I Tunisian Initial
Post by burnie43 »
Adam
I believe that you are a teacher ? Well over the past wee while I have become one of your students !!!
Thank you for sharing, I'm never too old to learn !
Have a good one.
cheers
Mark
[/color]
[/b]
DougC
Post by DougC »
Another great review Adam. IMHO Dragon is moving into the unaffordable range with their kits. $75 on Sprue Bros and no metal barrel, very little pe, and crappy DS tracks. The tool clasp thing is another easily fixable issue as you point out. Won't be getting my money for it.
mannloon
Post by mannloon »
DougC wrote:Another great review Adam. IMHO Dragon is moving into the unaffordable range with their kits. $75 on Sprue Bros and no metal barrel, very little pe, and crappy DS tracks. The tool clasp thing is another easily fixable issue as you point out. Won't be getting my money for it.
I agree with you. I clearly just keep buying them. But let me take the one for the team. This is worth...$45 I'd think.
OliveDrab
Post by OliveDrab »
Thanks for posting Adam, enjoyed your vid of the orange box early Tiger build also :th:
Curt :cheers2:
mannloon
Post by mannloon »
OliveDrab wrote:Thanks for posting Adam, enjoyed your vid of the orange box early Tiger build also :th:
Thanks OD, i'm working on painting that thing but i have garbage airbrushes and garbage airbrush skills that are keeping part 2 from progressing. I could have screamed today. I need to apprentice with someone that knows how to maintain an airbrush. It's weird how fast and comfortable i am with building and absolute rubbish i am at caring for an airbrush...
burnie43
Post by burnie43 »
I used to have the same problem Adam, got me an airbrush reamer and it is a great tool, plus I now soak the AB in a basin of hot water and keep the trigger pulled after my spraying ( always acrylics mind ) and I seem to have finally got it, the problem that I found was that the paint dried in the nozzle quite quickly so I tend to have a thinner soaked piece of tissue paper that I dab on the nozzle every few mins !
But really, your skills are top notch me thinks !!
Cheers pal
Mark
[/color]
[/b]
Just a quick question Adam, you mention near the end of the vid that you need to replace the tracks in the dragon offering, so I went back to see where you examine them in the video. I didn't see anything other than the flash you mention, but I couldn't tell for sure if the guide teeth were hollow... it that what you meant?
Other than that looks to be a marvellous kit. Just bought it based on your review in fact.
cib2265
Post by cib2265 »
Thanks Adam, nice review.
I think its a pretty good effort by Dragon, especially the side fenders and the Fiefels and a lot of other details.
A metal barrel would be nice yes, and maybe Magic tracks instead of DS, but I dont mind the latter.
We are spoiled as modellers, thats for sure.
I've just bought one from HLJ, and will build the "Heidi" version, since that's my wifes name!
cheers
mannloon
Post by mannloon »
Coen wrote:Just a quick question Adam, you mention near the end of the vid that you need to replace the tracks in the dragon offering, so I went back to see where you examine them in the video. I didn't see anything other than the flash you mention, but I couldn't tell for sure if the guide teeth were hollow... it that what you meant?
No they're hollow and only mildly bent, not a loss by any means. With the direction my obsession with the Tiger has gone I guess what i should have said was I will replace them. I seem to be more driven by the idea that it's an accurate replica than a base for a story driven piece which I know is more common. So I've started replacing all my tracks with indie links, i just like them better. If you can make Ds work these will be fine. I've been selling all of my Ds tracks.
Also, building Modelkasten, AFV Club and Friul gives me something to do if I'm skyping with people that isn't too intensive. I just bullt a set of those Chinese tracks by Kaizen I got cheap at a show. Surprisingly good.
Good enough.
I've no problem with DS Styrene, except for the cheap crap they used in the last couple of tiger releases. I'm not a fan of those. I can still make them work, but they're not as good as their earlier version.
Thanks.
DByrden
Post by DByrden »
cib2265 wrote: I've just bought one from HLJ, and will build the "Heidi" version, since that's my wifes name!
"Heidi" was a slightly different Tiger; its tow cables were laid out with their ends to the front, and they were the larger size of cable. Dragon's kit 6608 does not cover "Heidi" for that reason.
This is "Heidi" and Dragon are planning to cover it with the next Tiger kit.
David
cib2265
Post by cib2265 »
David
Thanks David - surely I can just move the tow cables around and use different size cable?
Not too hung up if its not perfect. Then again, I might use the kit as a base for a destroyed Tunisian Tiger too. Im liking building wrecked or captured German stuff more than operational ones..
DByrden
Post by DByrden »
Hi, and sorry about the delay. I don't visit this website often.
Yes, you'd need to move all the cable holding clips and source a thicker cable with larger end pieces - the standard cable that was used on most Tigers.
This is a great photo of the cable layout for "Heidi". The cable ends are up front, with the outer one ahead of the inner - that was changed later.
Of course, you'd need the "Heidi" decals too...they should appear in Dragon's next Tiger before very long, so you might get them from somebody.
David
cib2265
Post by cib2265 »
DByrden wrote:Hi, and sorry about the delay. I don't visit this website often.
David
Thanks David
I have most of those as spares in the stash, given the plethora of spares in my Dragon kits, plus I have the Afrika Tigers decal set which includes "Heidi".
Thanks again for your insight!
Return to “Armour Reviews”
