1/35 Miniart T70
BaldyBuilderBoy
1/35 Miniart T70
Post by BaldyBuilderBoy »
This is my first GB / SIG entry ever and is the first AFV that I have built since I made an Airfix 1/72 Chieftain Tank when I was about 8 yrs old so it could turn out to be a conversion build...... How to turn a Russian light tank into a train wreck :ooops: Anyway, we'll see over the next few weeks.
Ordered the kit late on Monday from eModels and it arrived this morning so a big shout out to them for lightning fast service. :th:
The T70 was designed by Nicholas Astrov's team as an improvement to the T60, which lacked firepower and armour protection in the face of increasingly powerful Nazi machinery. It was intended to replace both the T60 and T50 for use in the reconnaissance and infantry support roles.
The original design replaced the 20mm main gun of the T60 with a 45mm piece and increased the thickness of the armour giving a weight of 9.2 tonnes. To drive this heavier machine Astrov's team fitted two Gaz 202 petrol engines side by side each driving one track through separate transmissions, an arrangement which was rapidly exposed as being totally unsatisfactory so the layout was redesigned with the power plants fitted in line along the right side of the tank and delivering power to both tracks through one transmission and differential. The turret was also replaced at this time with one that could be welded from plate armour making manufacture much easier.
The T70 was operated by a crew of two. One driver and one commander, who also doubled up as his own gunner and aimer. This made operation of the tank in it's infantry support role very difficult for all but the most skilled of commanders.
Despite it's shortcomings the T70 was suitable for manufacture in smaller facilities than the T34 and consequently a total of over 8200 were built during 1942 and 1943.
T70's proved themselves to be capable but not exceptional and saw action in many of the great Russian campaigns of the war, including Kursk.
Specifications:
Weight 9.2 Tonnes
Length 4.29m
Width 2.32m
Height 2.04m
Max speed 28mph
Powerplant 2x Gaz202 petrol engines
Armament 45mm model 38 gun and 7.62mm machine gun
Armour 10mm - 60mm plate.
I'll start with a quick in box review and sprue shots.........
The kit comes in a nice big box with a good piece of box art on the front and on the sides there are photo's of the unpainted kit showing the PE parts attached. This is the "Special Edition" version and comes complete with a small amount of PE and some crew members, so that will be another foray into the relative unknown for me since I've only ever painted one figure before and that was in 1/48 scale.
The instructions look nice and clear and this is the first kit I've bought that has painting schemes in "Glorious Technicolor". so I'm delighted with that, in fact the only improvement on it would be if the crew figures were in " Supermarionation!!"
One neat little touch is the inclusion of a printed miniature map to go with one crew figure. I don't know if the traditionalists would approve or not but I think it's a nice little touch that shows thought for the builder, even if I choose not to use it.
The plastic is nice and crisp and the detailing looks sharp, although I can't really comment on the accuracy of it. My knowledge doesn't extend that far. On first look around it there are no obvious EPM's that would cause a problem.
I have watched an In box review of this kit on Youtube and they claimed no flash. This is not entirely accurate but what flash is present is minimal and will be easily cleaned away.
Now we come to the big negative point.... With the exception of the tracks, all the sprues were bunched into one plastic bag, including the few clear parts and the decals, neither of which were offered any protection from being jostled about by a jaunty postman happy in his work. Surely the industry standard should be better than this in the 21st century? Even the much criticised Airfix manage to put the clear parts into a separate bag from the rest of the plastic. :wall:
I'm really looking forward to this build. I have a definite idea in mind about how I wish to present the kit but firstly I need to get the thing built.
In the stash: Revell 1/32 Beaufighter, Airfix 1/48 Lightning, Academy 1/72 Catalina, Academy 1/72 B17F, and THAT Revell Voyager Kit.
TheTroyster
Re: 1/35 Miniart T70
Post by TheTroyster »
I built this kit this summer - it was great - no problems. Actually have a picture of the real # 275 - winter camp on it.
Troy :violin:
BaldyBuilderBoy
Thanks Troy. Did you put a build thread on ISM? I'd like to look at it if you did.
TheTroyster
BaldyBuilderBoy wrote:Thanks Troy. Did you put a build thread on ISM? I'd like to look at it if you did.
No build thread but I did post the final pictures up here on my member profile -- bottom of page one on page two are pictures of the diorama:
http://www.intscalemodeller.com/viewtop ... 69&t=14104
Seems like the hardest part - well I though the hardest part was going to be the tracks and they were- although once I put the fenders on the tank I took the tracks off to paint them and that is where I ran into problems - so if I was going to re- do this kit I would put the tracks on and keep them there and put up with the harder painting part later.
Troy
If you want the picture of T-70 # 275 let me know Ill post it here for you - if it is of interest -
Troy :violin:
BaldyBuilderBoy
Thanks Troy. Some great work there in your builds but the best thing by far is seeing the increase in your skills as you progress. The first builds are good but there's a clear journey going on as you apply the stuff you learned into the later builds.
:clap:
TheTroyster
BaldyBuilderBoy wrote:Thanks Troy. Some great work there in your builds but the best thing by far is seeing the increase in your skills as you progress. The first builds are good but there's a clear journey going on as you apply the stuff you learned into the later builds.
:clap:
Hey thanks man - very kind words.
Troy :violin:
BaldyBuilderBoy
So tonight I've made a start on this build, at this stage I'm thinking I'll build the late version but I won't have to really make a definitive choice about that until I get to sorting out some of the hatches....
Dryfitting the main body components indicates that this should go together quite nicely which will be a bonus after the Mig 29 I'm currently part way through.
First job with this build was to remove some of the plastic to accommodate PE. It's rather disconcerting to find that the first process of the build is to carry out some surgery...
Surgery done...
and some PE attached. I've also put into the picture the parts which will be replaced with PE just for reference...
Looking forward to really getting on with this tank tomorrow, lots more PE work and pressing on with other sub-assemblies.
OliveDrab
Post by OliveDrab »
Looking forward to see how this goes as this one was added to the stash recently, looks nice so far.
Curt :cheers2:
BaldyBuilderBoy
Further progress on the tank over the last couple of days.
I have got the "running gear" fitted. Most of the pieces were marginally too large for their location holes but that was fine. It meant I could sand them carefully to a nice snug fit, and I've started to fit some of the smaller external fittings like tow hooks and hoops etc. I have shied away from too much PE work after nearly losing some small parts of my Mig build so I have concentrated on getting some of the turret cleaned up and test fitted.
One bit of PE I did play about with was for the radiator grille... I'd had to cut out the panel to accommodate the PE but from the instructions I wasn't sure if I needed to leave a rim for the PE to sit on.....
But having cut and cleaned a piece of the grille for test fitting I can now see that the panel edges are tapered so I need to clean out the remaining rim that I left and get these grille pieces fitted properly.
The turret and spare wheel are all dry fitted in these pictures and since taking them I have added a couple of small PE parts to the turret as well.
Next step is to sort out that grille properly and get the armament figured out. However I have now decided that I am definitely building a late model T70......
BaldyBuilderBoy
Further progress to report and some mixed success.
I've cleaned out that radiator cover and attached the PE grilles. They are really looking the part but I'm finding that bending the PE is a frustrating job without a PE bending tool. My technique is to use a metal drinks coaster and a steel ruler, then place the PE on the coaster with a slight overhang, hold in place with the ruler and some firm pressure and then use the blade of some scissors to affect the bend. It's damned fiddly and gives mixed results at best as can be seen from the different bends of the tabs on the back of the turret. With this in mind I'm rather nervous about attempting to bend the tiny hinges and catches for the ammo boxes and might just leave the moulded plastic ones in place.
There is no detail whatsoever inside the tank but I want to have at least one hatch open so I've given the interior a coat of matt black so I don't end up with bare plastic on view, at the same time I have primed the radiator grille because there is a PE mesh cover to go over it and I think it will paint easier before I fit the mesh.
Most of the plastic work is now done with the exception of the tracks. I've had a practice go at joining them but it's ridiculously fiddly, they are quite delicate and they are all individual links so there are more than 80 each side, little wonder then that the part count on the box claims in excess of 400 parts, most of them are the tracks.... :crazy: This might result in my investing in some Friul tracks, we'll see how it goes first.
I've had a problem with a couple of the track cover stays which have broken. maybe it's because I'm ham-fisted, but anyway I figured that the untidy bends on some of the PE parts and the broken stays will all add character to the final result, after all it's a combat vehicle not an entry in a concourse competition.
All in all though,I'm finding that the model is going together quite well. I've definitely decided to build the later version T70 and would like to thank Jonas Coleman and Le Renard Bergman for helping me decipher an error in the instruction sheet regarding the correct hatch covers. :th:
I'm now getting close to that exciting stage where the paints come out and the plastic gets converted to hard steel......
TheTroyster
I kind of didn't like those - I don't know what they are called - grab handles went on kind of wonkey. Have fun with that painting.
Troy :violin:
BaldyBuilderBoy
Thanks Troy, I will. This has been only my second time using PE so I'm on a steep learning curve at the moment. I've still got a couple of bits to go on but wanted to leave them till as late as possible because they look like just the type of thing to get knocked off during handling. How did you get on with the tracks? Looks like about 6 hours of living hell to me. :eeek:
martin57
Post by martin57 »
YOU are doing great so far , nice kit.
good luck with the rest of it . :th: :th:
BaldyBuilderBoy
Thanks Martin. Really looking forward to getting stuck into the painting job. Gonna review some vids on youtube to remind myself of what I want to be doing.
BaldyBuilderBoy
So today I have made a good push to get the model ready to paint.
I started off by looking at those PE hinges that were freaking me out so much yesterday and having cut one out of the frame and made an attempt at bending it I decided that with the tools I'm using I would be well advised to leave the moulded plastic ones in place for this build... Maybe next time...
Having decided against the hinges I got the mesh cover over that grille and made a couple of judicious and deliberate pokes with the tweezers to give it some minor damage, that done I dry brushed some of the weaponry interior controls to give a used look about them without going too heavy handed on it.
Finally some work on the turret and I was ready to move on to the primer coat. I'm using Vallejo polyurethane in black and intend to try my hand at some basic modulation for the main colour. It's amazing how much flash photography shows up the bits that you miss on what you believed was a nice even coat of paint. :crazy:
BaldyBuilderBoy
I've left this little tank to one side for a while so I could progress my Mig 29 build, but I'm very conscious that time is pressing on if I want to complete my first GB.
I've given up on the tracks, they are a dead loss as far as I can tell. Plastic individual links that are supposed to snap together..... 80+ links to each track..... well after about two hours of trimming, cleaning, snapping, coaxing and swearing I'd never managed more than a three link chain before the whole lot fell apart again. It seems to me that if I glue them then they probably wont contour around the wheels properly. So I've decided to invest in some Fruil tracks and Ultimate burnishing liquid when the next wages come through.
After the frustration of the tracks I dug the kit out again and got all the wheels cut and cleaned ready for primer and I assembled one of the figures for priming too. This is gonna be a walk into the dark for me, as I said before I've only ever really tried painting one figure before and that was 1/48 scale.
I've also made a start on the painting of the tank itself. The exhausts were given a rusty undercoat before spraying with hairspray. As for the main colour I want to try a bit of modulation on this build so after priming in black I have used Vallejo US dark green as the dark base.........
I now need to add the main colour and highlights using the MIG Russian Green base and Russian Green Light base.
Next update should show the colour scheme coming on well and hopefully some progress with the decals and maybe a bit of weathering......
felisbarcinonensis
Post by felisbarcinonensis »
Looking gooood mate!!!! :cheers2:
