Eduards 1/48 Polikarpov I-16 Type 24 no2
TomasGould
Post by TomasGould »
Here we go again :)
After i could not decide on my which paint scheme I would go for on my last build I will build one more in this GB :)
Mr.T
TomasGould
Re: Eduards 1/48 Polikarpov I-16 Type 24 no2
Last build was Boris Safonovs legendary I-16 and this time i will go for fighter ace Genadij Tsokolayevs I-16 from the Baltic Fleet :)
Mr.T
TomasGould
Here's some history about the I-16
Mr.T
TomasGould
I started a little with the cockpit and dry fitted The fuselage halves :)
Mr.T
:pop: I've got this one but I think all of the colour schemes have been done now!
TomasGould
Avgas wrote::pop: I've got this one but I think all of the colour schemes have been done now!
No!! The 2 dark green schemes is left lol :)
And congrets Avgas for the januari price draw :)
Mr.T
Cheers mate, never built a tank before! Or a gun with tracks which is what I think it is.
rodrant
Post by rodrant »
A good choice of color scheme :-) , exactly what I will do , and yes , I'm just thinking to buy another one and do the same as your first build :-) , I'm watching this one !
Cheers ,
António
a lot of stuff right now :-)
TomasGould
rodrant wrote:A good choice of color scheme :-) , exactly what I will do , and yes , I'm just thinking to buy another one and do the same as your first build :-) , I'm watching this one !
It sounds like a great idea :) I really think you should build one more :)
Mr.T
TomasGould
When i looked in the instructions they say that inside of the fuselage should be painted grey. But on cockpit pics of the real aircraft the inside is painted blue :) evan some cranks should be green instead of grey.
Mr.T
rodrant
Post by rodrant »
oh s....t , now mine it is grey :-)
well it is hard to make all the right choice of colors you know , but nice color picture of the bird !
Cheers ,
António
TomasGould
rodrant wrote:oh s....t , now mine it is grey :-)
thats no problem rodrant couse when its finished you want see it anyway :)
I painted my last one blue too :)
Its alot of small things in the instructions you have to look twice to get it right :)
Like the exhoust pipes, on the left upper hole it should be 2pcs in one hole but on the right upper hole only 1pcs. I noticed that in the end of my last build :) but i had not mounted the pipes yet when i noticed it :)
Mr.T
TomasGould
Base coating done on the cockpit and also on the engine :)
I used a mix of Vallejo model air 71.008 Pale Blue and 71.001 white for the cockpit.
Val air 71.057 Black for the instrument panel
Val air 71.072 Gungrey for the engine
Mr.T
TomasGould
Now all the PE for the cockpit is ready for some colour :)
I will use a mix of Tamiya XF62 OD and XF2 white for these parts :)
Mr.T
TomasGould
Now the paint is on :)
Mr.T
TomasGould
Now some detail painting, washing and chipping is done :)
I will apply some dust on the floor :)
Its now time to mount everything in the fuselage halves :)
I'm not 100% satisfied with the wash on the fuselage :/
Mr.T
TommyKillander
Post by TommyKillander »
Geeez... I have to buy myself one of these I-16s... They look so cool 8-)
Great start (again) and good luck with the build !
Tommy
TomasGould
TommyKillander wrote:Geeez... I have to buy myself one of these I-16s... They look so cool 8-)
Tommy
Its a really fun kit to build so i really think you should build one sometime :) And thanks for the good luck :)
Yesterday evening was the big filler and sanding evening :) I've glued the fuselage halves together and filled and sanded and filled and sanded and filled and san...... And so on :) so now I really hope the seam want be seen otherwise its just fill and sand some more :)
The seam line on this fuselage was much harder to get rid of compared to my last I-16.
Mr.T
TomasGould
Cockpit weathered and after i took this photo i also mounted the foot pedals to the rudder and mounted all in the fuselage :)
Mr.T
TomasGould
I masked and filled a little gap between the wings and fuselage.
And now it starting to look like an aircraft :)
Mr.T
TomasGould
For that version I'm building i should use part E23
But in the last second i saw that i had to cut off the two bars sticking up
I fixed that and now is it ready for primer :)
Mr.T
TomasGould
Now I've primer it and i used Tamiya surface primer white.
I used white becouse the paint scheme is just light colours :)
I also did some pre shading using Tamiya XF1 Black
Mr.T
TomasGould
Now the plane is painted and tomorrow i will give it a coat of clear :)
Upper side was painted with a mix of vallejo model air
71.001 White, 71.049 medium sea grey and 71.057 Black
Under side was also painted with a mix of val air
71.008 Pale blue and 71.001 white
Mr.T
Looking good Tom. The photo three up there where you have the preshading on the white primer looks great. I would be tempted to leave it like that and bang a gloss coat on it. Bit weird I know but it does look nice.
rodrant
Post by rodrant »
Very nice detail in the build , admire your clean build :th:
I have also the same issues in filling those areas in mine , didn't noticed the two pins , good spot and great observation buddy !
This one will be another clean and beautifull build ! Nice litlle kit ! You doing great !
Cheers ,
António
JudgeDredd
Post by JudgeDredd »
Nice pre-shading and good build so far.
I AM the Law
TomasGould
rodrant wrote:Very nice detail in the build , admire your clean build :th:
JudgeDredd wrote:Nice pre-shading and good build so far.
Avgas wrote:Looking good Tom. The photo three up there where you have the preshading on the white primer looks great. I would be tempted to leave it like that and bang a gloss coat on it. Bit weird I know but it does look nice.
Thanks guys for the kind words :)
Now the engine is painted :)
I used vallejo model air 71.072 Gungrey as a base color and gave it a dark brown wash. After that i painted black around the cylinders with vallejo 71.057 Black and last i gave the cylinders a drybrush with Humbrol enamel 11 silver :)
Sorry for the bad pic :)
Mr.T
TomasGould
A clear coat is on and I hope for some decaling tomorrow or Saturday :)
Mr.T
TomasGould
Decals on and now i will give the decals a gloss coat before a wash.
Mr.T
TommyKillander
Looks awesome ! :pistols:
Well done!
Tommy
TomasGould
TommyKillander wrote:Looks awesome ! :pistols:
Well done!
Tommy
Thanks Tommy!! I hope to finish it this upcoming week :)
A wash is done and i used artist oils black and raw umber.
After that a gave the model a coat of flat varnish.
Next up will be some chipping and small detail painting :)
Mr.T
TomasGould
Detail painting and chipping done :)
I also painted and mounted everything in cowling :)
Mr.T
What do you use for your chipping? Looks really good.
TomasGould
Avgas wrote:What do you use for your chipping? Looks really good.
Thanks Avgas :)
I first masked the edges where i should chip, and then I used a bit of a sponge with almost dry Humbrol enamel 11 on and dipped on the areas :)
Mr.T
I'll give that a go next time, cheers.
TomasGould
Avgas wrote:I'll give that a go next time, cheers.
You're welcome Avgas :)
Todays work was not much I prepared the exhoust pipes for painting and i drilled out the Machineguns and venturi probe :)
Mr.T
TomasGould
Today I've started with The landing gear :)
The version I'm building did not have any undercarriage doors.
Mr.T
TomasGould
Exhoust pipes painted and mounted
I used Tamiya XF-10 flat brown as a base and weathered them with mig production pigment old rust and black smoke.
I also finished the undercarriage :)
Mr.T
TomasGould
Mr.T
TomasGould
Ok, this sucks!!
The only thing left to do is paint the prop and my colour is empty!!! Lol
I get a new one in the week :)
But here it is so far :)
And here it is together with my other entry in this GB :)
Mr.T
TomasGould
The prop is now painted :)
The instructions said it should be black but on some pics of the real bird it had a flat/semi flat aluminium prop :)
I will mount the prop on the plane and then my build is finished :)
Mr.T
TomasGould
Mr.T
