Today, I sprayed and sanded primer coats.
I started by misting on Tamiya primer from a rattle can. I did light coats until I had full coverage.
Once the primer had dried, I sanded the model with 220, then 320 grit sandpaper. This filled in a majority of the scratches that were made when I sanded all of the filler putty I used.
It was primer time once again. This time I used Model Master enamel primer. I sprayed a couple of light coats followed by wet coat.
As you probably can see, much of what detail was engraved in the plastic has been lost. Since this will be a stand model, I am OK with that. Stand models are usually polished and very smooth. While I'm not going to go that far. I think the model with present well in a normal matte coat.
