Hi All,
In tooling up the new mancave for my modeling I'm looking for a fan patern airbrush. My pockets aren't deep enough and I'm not willing to fork over 4 or 500 euro that wil only be used for priming, base and clear coating. I had me a little search on google and found an option that will work with the current compressor I have.
I'm looking into the Sparmax GP-825, unfortunately I cant find any (online) retailer that sells them. So i'm starting to wonder whats out there on the market at an affordable no thrills level.
Thanks for the help
Fan Patern Airbrushes
- Vleugelmoer
- Sergeant Major of the Army
- Contact:
Damm the glue is getting to me
- digger303
- General
Re: Fan Patern Airbrushes
Seems to be plenty spamax's gp-825available
http://www.modellingtools.co.uk/sparmax ... 1797-p.asp
http://www.pk-pro.de/Sparmax-GP-825-Airbrush_1
https://www.everythingairbrush.com/airb ... ozzle.html
http://www.ebay.com.au/itm/like/3806670 ... 107&chn=ps
Or different AB
https://sites.google.com/site/donsairbr ... sche-talon
https://www.semashow.com/press/2015/08/ ... -accessory
Or different AB
OneSmallStep1966
- Command Sergeant Major
That's only a little less than what I paid for my Iwata RG-3-L direct from Japan. Check out Page 7 on this thread where we discuss this in depth. http://www.intscalemodeller.com/viewtop ... 5&start=60
- digger303
- General
just make sure your compressor is large enough.
- Vleugelmoer
- Contact:
That exactly why I started this thread, can't seem to find any air consumption figures for this airbrush. Have also contacted some of the retailers above as wel as the manufacturer them self but stil waiting on a reply from all of the above on this.digger303 wrote:just make sure your compressor is large enough.
Would be shame to have a new tool that can't be used due to air supply issues...
Jetblast
- Private
The GP-825 will have a similar air consumption to the Iwata Kustom HP-TH (same nozzle size & similar design). In fan pattern Iwata recommend a minimum compressor air flow rating of 1.2CFM (34 L/Min) for the HP-TH.
30 L/Min would probably suffice, more powerful standard airbrush compressor at 25 L/Min or thereabout will work fine in round pattern & if fitted with a tank may give short lived (5 seconds or thereabouts) fan pattern capability as the tank drains down, but you're then going to have to wait for tank recharge...... Smaller, lower air flow compressors are unfortunately pretty much out of the question for operating in fan pattern......
aade
- Sergeant
Do you want a fan pattern for wider coverage or some other reason? I would look toward a wide pattern round brush unless you have specific requirements on a fan. Getting a fan spray pattern requires a lot of air. Lots more than a small airbrush compressor will output.
The Iwata RG3 will most likely do the job nicely. An Iwata HP-TH or GSI Creos Procon PS290 are airbrush style guns but with triggers.
-Alex
-Alex
