Low RPM powered Drill.
BrotherZaah
Post by BrotherZaah »
Hi everyone,
I'm looking for a low rpm drill that can take very small bits <1mm and upwards.
I have a Dremel multi tool but even at its lowest rpm its too fast and just melts plastic rather than drilling it.
Does anyone have reccommendations?
- BZ
"I have not failed, I've just found 10000 ways that won't work"
http://studiorowlands.com/
Re: Low RPM powered Drill.
Tamiya makes a drill as a model kit you put together that is battery powered....Lee did a review of it in the videos I believe
Yep, found it
[youtube]vBvJZUJRiaE[/youtube]
You want a proxon, they go from 500rpm up to 20,000 and wipe the floor with dremels and even with he power transformer they cost about £50
If you want product codes let me know
BrotherZaah
Please Paul that would be excellent.
- BZ
Vleugelmoer
Post by Vleugelmoer »
Proxon would be my first choice of tool for this application. Providing a general geagraphic location will also help fellow members to give you a more refined answer when they reply.
As always happy modeling and keep sticking styrene
BrotherZaah wrote:Please Paul that would be excellent.
- BZ
This is where i got it from http://www.chronos.ltd.uk/acatalog/copy ... Tools.html
And this is what i got and the product codes
BrotherZaah
Thank you very much sir!
BrotherZaah wrote:Thank you very much sir!
If you get the slightly larger transformer you will find it more useful and ultimately cheaper.
Proxon also do a very useful pen sander which will plug into the same transformer.
Plus electric knife for carving landscapes
:th:
Augustus
Post by Augustus »
i can find the Proxxon tools easy enough here in Oz but not much in the way of accessories/bits. Do they have their own range or would Dremel bits fit them?
Any bits fit them, they have a chuck and not collets :thumb2:
Return to “Tools”
