Paul's 1/72 Italeri Short Sunderland Mk1 "Porcupine"
My proposed build of the Italeri Short Sunderland, looks to the a good kit apart from the gapping panel lines.
I've added a few extras, exterior pe, zoom cockpit pe and the all important canopy mask set.
[youtube]g8-eX0cnwNw[/youtube]
[youtube]Di-tShoowGo[/youtube]
The Short S.25 Sunderland was a British flying boat patrol bomber developed for the Royal Air Force (RAF) by Short Brothers. It took its service name from the town (latterly, city) and port of Sunderland in northeast England.
Based in part upon the S.23 Empire flying boat, the flagship of Imperial Airways, the S.25 was extensively re-engineered for military service. It was one of the most powerful and widely used flying boats throughout the Second World War, and was involved in countering the threat posed by German U-boats in the Battle of the Atlantic. RAF Sunderlands also saw service throughout the Korean War and continued in service until 1959. It also took part in the Berlin airlift. Sunderlands remained in service with the Royal New Zealand Air Force (RNZAF) until 1967.
Sunderlands converted for civil use, known as Short Sandringhams, continued in airline operation until 1974. A single airworthy example remains on display in Florida at Fantasy of Flight.
Development
The early 1930s saw intense competition in developing long-range intercontinental passenger service between the United Kingdom, the United States, France and Germany, but the United Kingdom had no equivalent to the new American Sikorsky S-42 flying boats or the German Dornier Do X. However, in 1934, the British Postmaster General declared that all first-class Royal Mail sent overseas was to travel by air, establishing a subsidy for the development of intercontinental air transport in a fashion similar to the U.S. domestic programme a decade earlier. In response, Imperial Airways announced a competition to design and produce 28 flying boats, each weighing 18 long tons (18 t) and having a range of 700 mi (1,100 km) with a capacity for 24 passengers.
The contract went to Short Brothers of Rochester and while the first example of the new type, the S.23 Empire was under development, the British Air Ministry was taking actions that would result in a military version. The 1933 Air Ministry Specification R.2/33 called for a next-generation flying boat for ocean reconnaissance. The new aircraft had to have four engines but could be either a monoplane or biplane design.
Specification R.2/33 was released roughly in parallel with the Imperial Airways requirement, and while Short continued to develop the S.23, it also worked on a response to R.2/33 at a lower priority. Chief Designer Arthur Gouge originally intended that a 37 mm COW gun be mounted in the bow with a single Lewis gun in the tail. As with the S.23, he tried to make the drag as low as possible, while the nose was much longer than that of the S.23. The military flying boat variant was designated S.25 and the design was submitted to the Air Ministry in 1934. Saunders-Roe also designed a flying boat, the Saro A.33, in response to the R.2/33 competition, and prototypes of both the S.25 and A.33 were ordered by the Ministry for evaluation. The initial S.25 prototype first took flight in October 1937.
As with all water-based aircraft, there was a need to be able to navigate on water and to control the craft up to and at a mooring. In addition to the standard navigation lights, there was also a demountable mooring mast that was positioned on the upper fuselage just aft of the astrodome hatch with a 360-degree white light to show that the aircraft was moored. The crewmembers were trained in common marine signals for watercraft to ensure safety in busy waters.
The craft could be moored to a buoy by a pendant that attached to the keel under the forward fuselage. When the craft was off the buoy, the forward end of the pendant was attached to the front of the hull just below the bomb aimer's window. For anchoring, there was a demountable bollard that fixed to the forward fuselage from where the front turret was retracted to allow an airman to man the position and pick up the buoy cage or to toss out the anchor.
A mooring compartment was situated in the nose of the Sunderland, containing anchor, winch, boat-hook and ladder. The front turret was designed to slide back, enabling the crew to secure the aircraft to a buoy, as demonstrated here.
A standard stocked anchor was stowed in the forward compartment alongside the anchor winch. Depending on the operating area, a number of different kinds of anchor could be carried to cope with different anchorages.
For taxiing after landing, the galley hatches were used to extend sea drogues that could be used to turn the aircraft or maintain its crosswind progress (by deploying the drogue on one side only), or to slow forward motion as much as possible (both deployed). When not in use, the drogues were hand hauled back inboard, folded, and stowed in wall-mounted containers just below the hatches. Operation of the drogues could be a very dangerous exercise if the aircraft was travelling on the water at speed or in strong currents, because the approximately three-ft (1 m) -diameter drogue would haul up on its five-tonne attachment cable end inside the galley very sharply and powerfully. Once deployed, it was normally impossible to recover a drogue unless the aircraft was stationary relative to the local tidal flow.
Another means of direction control on the water was by application of the rudder and aileron flight controls. The ailerons would cause asymmetric lift from the airflow and, ultimately, drop a float into the water to cause drag on that wing. The pilots could vary engine power to control the direction and speed of the aircraft on the water. In adverse combinations of tide, wind, and destination, this could be very difficult.
Sunderland Mark I[edit]
The RAF received its first Sunderland Mark I in June 1938 when the second production aircraft (L2159) was flown to 230 Squadron at RAF Seletar, Singapore. By the outbreak of war in Europe, in September 1939, RAF Coastal Command was operating 40 Sunderlands.
The main offensive load was up to 2,000 lb (910 kg) of bombs (usually 250 or 500 lb), mines (1,000 lb) or other stores that were hung on traversing racks under the wing centre section (to and from the bomb room in the fuselage). Later, depth charges (usually 250 lb) were added. By late 1940, two Vickers K machine guns had been added to new hatches that were inserted into the upper sides of the fuselage just aft of the wing, with appropriate slipstream deflectors. A second gun was added to the nose turret. New constant speed propellers and deicing boots were installed as well during 1940.
The Sunderland had difficulty in landing and taking off from rough water, but, other than in the open sea, it could be handled onto and off a short chop, by a skilled pilot. Many rescues were made, early in the war, of crews that were in the Channel having abandoned or ditched their aircraft, or abandoned their ship. In May 1941, during the Battle of Crete Sunderlands transported as many as 82 armed men from place to place in one load. Steep ocean swells were never attempted, however a calm ocean could be suitable for landing and takeoff.
Beginning in October 1941, Sunderlands were fitted with ASV Mark II "Air to Surface Vessel" radar . This was a primitive low frequency radar system operating at a wavelength of 1.5 m. It used a row of four prominent "stickleback" yagi antennas on top of the rear fuselage, two rows of four smaller aerials on either side of the fuselage beneath the stickleback antennas, and a single receiving aerial mounted under each wing outboard of the float and angled outward.
A total of 75 Sunderland Mark Is were built: 60 at Shorts' factories at Rochester and Belfast, Northern Ireland, and 15 by Blackburn Aircraft at Dumbarton.
Re: Paul's 1/72 Italeri Short Sunderland Mk1 "Porcupine"
:pop: Nearly bought this kit a while ago but the 'padded quilt' panelling on the fuselage put me off.
Nev
Post by Nev »
My dad used to watch these take off from the river Medway when he was a small boy. Looking forward to this one mate :thumb2:
On the Bench...
Found out a couple of years ago that my mate's Dad used to fly them in WWII. Just dropped it into conversation one day and I was like 'Knowing my interest in aviation you just decided to tell me that!!!.'
NorthernModeller
Post by NorthernModeller »
stunning aircraft, already liking the write up and history of the bird
rodrant
Post by rodrant »
Love this aircraft ! Believe it or not I was looking for one some weeks ago , and I was to buy it , and the Big ED for it . The Big Ed for it is nice it has the plataform engine maintenance and some more stuff besides the goodies that you have , in the end other stuff enter in priority here in the house (think it was a figure :-) )
One to follow for sure , as I didn't quit yet on this kit :lol:
Good luck Paul !
Cheers ,
António
a lot of stuff right now :-)
pourquoi61
Post by pourquoi61 »
Looks like I will have to leave the old Airfix Sunderland in the stash now, no good luck mate with that one. :th: :th: :th:
mick
Post by mick »
:pop: :pop: :thumb2: great choice
gaz45
Post by gaz45 »
Very nice choice mate
Cheers fellas
I had a quick muck about on the Live at the bench update on friday night to see how it goes together and the size of it
Its a big bird but seems to go together not too bad
Wing roots will need some work and those panel lines are idiotic
So i made start to the cockpit and interior, its very basic even with the pe zoom set and with about 400 ejector pin marks i wasn't going to spend hours removing i did a basic paint and wash job on it, barely any of it is viable once the fuselage halves are together.
Cockpit was primed in Ultimate black primer
Then sprayed in interior green and given an oil wash
Very basic interior
Glued and clamped :thumb2:
NorthernModeller
Coming along great mate, Great detail in the cockpit and very nicely weathered :)
EricM
Post by EricM »
looking great, possible water dio with this one? looking forward to the rest.
On The Bench
1/72 Finemolds ME410/A-1
alextheblue
Post by alextheblue »
Cheese and rice Paul, is there any subject you're not building!! Great progress as always.
Apologies, slightly off topic, but I especially love all the bikes you've been building recently - absolutely stunning! :th: :clap: :bow::
www.alextheblue.com
gaz45
Post by gaz45 »
Looking really good so far mate
Les
Post by Les »
Less than 24 days left on this one man; how is it coming along?
Les wrote:Less than 24 days left on this one man; how is it coming along?
Its not, bugger off lol
