Trumpeter 1/32 JU87-R Stuka
Post pictures of your unstarted kits and in progress build pictures and updates
Les0012
Post by Les0012 »
Okay this is the third attempt to do this post.........
Have went and bought the JU87-R in 1/32, This will be the first try at a build in this scale.
The box art.
ImageDSCF0035 by Les Goodison, on Flickr
The sprues are well packed in the box with a section for the clear canopy parts.
ImageDSCF0039 by Les Goodison, on Flickr
Also bought some aftermarket for the build , seat belts, interior and canopy masks
ImageDSCF0036 by Les Goodison, on Flickr
ImageDSCF0037 by Les Goodison, on Flickr
ImageDSCF0038 by Les Goodison, on Flickr
The plastic looks good and well detailed, I won't post picks of all 13 sprues as they will be well documented in other threads, there are 315 parts and a photo etch fret with 14 parts as well and the tyres are made of hard plastic.
ImageDSCF0040 by Les Goodison, on Flickr
ImageDSCF0041 by Les Goodison, on Flickr
ImageDSCF0043 by Les Goodison, on Flickr
ImageDSCF0048 by Les Goodison, on Flickr
The clear sprue is well packed in both the box and its own packaging I am not opening the packing until I neen to.
ImageDSCF0047 by Les Goodison, on Flickr
The decal sheet is in its own bag and again will not be opened until required,
ImageDSCF0052 by Les Goodison, on Flickr
The instructions are in a pamphlet of 16 pages and look very detailed, the colour call out gives the paint schemes for 3 aircraft ( I hav'nt decided which one I will do yet.
This looks like daunting build for my limited skills but I will give it my best shot and hopefully will finish it in time.
Les
Les0012
Re: Trumpeter 1/32 JU87-R Stuka
Post by Les0012 »
A couple of pictures taken from Wikipedia
ImageJunkers_Ju_87_R-2_III_St.G_2_Greece_1941 by Les Goodison, on Flickr
ImageM0021739_040 by Les Goodison, on Flickr
A short description of the R model taken from info in the kit box,
A long range version of the JU 87B was also built, known as the JU 87R. They were primarily intended for anti shipping missions. The JU 87R had a B-series airframe with an additional oil tank and fuel lines to the outer wing stations to permit the use of two 300L under wing drop tanks. This increased fuel capacity to 1,080 litres, (500 litres in the main fuel tank of which 480 litres were useable + 600 litres from the drop tanks). To prevent overload conditions, bomb carrying capacity was often restricted to a single 250Kg bomb if the aircraft was fully loaded with fuel.
Total production amounted to 972 Ju 87-R (105 R-1,472 R-2, 144 R-4), all built by Weserflug. The last JU87R rolled off the production line October of 1941.
Les
Cymru
Post by Cymru »
Don't be daunted and just DIVE in :lol: :pop:
Hanger:
STASH
WIP:
Current Projects
Orange Air Virtual Airline
Coops
Post by Coops »
good luck with your build nd have fun with the seatbelts...
curious to know if in your eduard interior you also get instructions for a part to be made molding from sprues?
coops
Arty farty me.
https://www.facebook.com/Coopscreativecorner/
On Da bench
1/32 hasegawa Stuka.. waiting for weathering
1/48 Wessex UH.5
1/35 Rye Field M1A1 breacher
Les0012
Post by Les0012 »
Nope can't see anything about moulding from the sprue but will be vigilant when using the pe.
Thanks Les
Les0012
Post by Les0012 »
Quick update on the build,
Started last night and built up the engine block and components, I have primed them this morning in Vallejo Base Grey (71-097), just for a change to see what it came out like, and not to bad me thinks.
Leaving it to dry for a while then it will be painted in Mr Hobby H339 Engine Grey,Mr Hobby H70 RLM 02 Grey and Steel a colour which I don't have yet.
ImageDSCF0055 by Les Goodison, on Flickr
ImageDSCF0057 by Les Goodison, on Flickr
ImageDSCF0059 by Les Goodison, on Flickr
Thanks for looking in Les
Les0012
Post by Les0012 »
Been a while since I updated the build, been a bit busy but anyway here it is so far,
The engine block has been built and painted in Mr Hobby RLM 02,Steel and engine gray and a bit of weathering with AK engine oil stain and abtielung 502 engine grease and streaked with AK thinners.
ImageDSCF0067 by Les Goodison, on Flickr
ImageDSCF0068 by Les Goodison, on FlickrImageDSCF0066 by Les Goodison, on Flickr
The cockpit is nearly at the complete point just a few bits of pe to go in and the rear seat belts that can't go in until the walls are on. Painted in RLM 02, the floor in RLM 66 black gray then gloss coated and AK European dust pigment. The seat belts are Eduard.
ImageDSCF0061 by Les Goodison, on Flickr
ImageDSCF0062 by Les Goodison, on Flickr
ImageDSCF0063 by Les Goodison, on Flickr
ImageDSCF0064 by Les Goodison, on Flickr
ImageDSCF0065 by Les Goodison, on Flickr
That's as far as it goes for the moment, thanks for looking Les
Coops
Post by Coops »
Awesome work on the cockpit... may i ask if you used a "fixer" to keep the dust etc in place
Coops
Arty farty me.
On Da bench
1/48 Wessex UH.5
Les0012
Post by Les0012 »
Coops wrote:Awesome work on the cockpit... may i ask if you used a "fixer" to keep the dust etc in place
Coops
Thanks for the comment Coops,
The dust is fixed with AK pigment fixer
Les
neat, great fantastic stuff :jd:
Novorus
Post by Novorus »
Looks amazing mate, :pop:
James
Les0012
Post by Les0012 »
Onwards and upwards as they say,
The build is progressing "slowly" as I think I am way out of my depth here,
The cockpit is in and the to fuselage half's are on and together, not a bad fit but I did need a bit of filler here and there,
ImageDSCF0070 by Les Goodison, on Flickr
Not the best photo but you get the idea!
Next the wings and nose were fitted, again a fairly good fit but a wee bit of filling required,
ImageDSCF0069 by Les Goodison, on Flickr
The gun bays are built and fitted into the wings
ImageDSCF0073 by Les Goodison, on Flickr
I have now primed the model with Ultimate grey and it has shown up a few spots where a little Mr surfacer will be used to fill the gaps
ImageDSCF0074 by Les Goodison, on Flickr
ImageDSCF0076 by Les Goodison, on Flickr
Well that's as far as I have managed to get so far
Thanks for looking at my mess Les
Novorus
Post by Novorus »
Les doing better than me, mot even started. Been away from the bench for a while and think i may just have to pull out on this one.... :bash:
James
Novorus wrote: Fri Feb 10, 2017 11:13 pm Les doing better than me, mot even started. Been away from the bench for a while and think i may just have to pull out on this one.... :bash:
doesn't matter if you don't finish on time....life screws things up at times.... :cheers2:
Novorus
Post by Novorus »
Yer Les your right, just not wanting to start another build just yet. Bench is already over crowded, plus my mother in law is here for a few more weeks yet so family first and all that.
To be fair she would mind me hiding away, but feel its rude. Plus after yesterday i may just have a cunning plan !!!!
James
Les0012
Post by Les0012 »
Update,Update,Update
Okay so I have now managed to get some paint on and have her up on her legs,
The whole aircraft was primed in Ultimate Grey, and the underside painted in Tamiya XF-23 Light Blue, The Topside is done in Mr Hobby Aqueous H66 RLM 79 Sandy Brown and a bit of post shading with a little XF-1 Flat Black added to the H66. I'm not very good at this painting thing but am quite happy with it.
The chipping (if you can call it that), is the old sponge and Tamiya X-11 Chrome Silver method
Now I have to give her a gloss coat, decals and then get the weapons built painted and on and a bit of weathering
Here's some piccies of her at the current stage of the build.
ImageDSCF0077 by Les Goodison, on Flickr
ImageDSCF0078 by Les Goodison, on Flickr
ImageDSCF0079 by Les Goodison, on Flickr
ImageDSCF0080 by Les Goodison, on Flickr
Thanks Les
Les0012
Post by Les0012 »
Ok everyone, It's been a while since I updated the build,
The Stuka is now basically complete minus weapons.
She has been painted in Sand Brown on top with Light Blue on the underside gloss coat 1 was AK gloss, then decalled and Gloss coat 2 Hannants Gloss. She was then covered in Ultimate Dark Dirt and when dry washed off with water and paper towel and then finished in AK Matte coat.
Some photos of the bird as she stands
ImageDSCF0081 by Les Goodison, on Flickr
ImageDSCF0083 by Les Goodison, on Flickr
ImageDSCF0084 by Les Goodison, on Flickr
ImageDSCF0085 by Les Goodison, on Flickr
ImageDSCF0086 by Les Goodison, on Flickr
ImageDSCF0087 by Les Goodison, on Flickr
As it's only the bomb along the centre line and the two external drop tanks that are going on the next photos will probably be the final reveal.
This, for me, has been a monster of a build but I have enjoyed it, mostly, hope you have too.
Thanks for looking and the encouragement along the way
Les
peppie
Post by peppie »
Looking good :cheers2:
Love the colour..
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
Very very nice :bow:: :th: :cheers2:
Novorus
Post by Novorus »
looking sweet to me, love it
James
