Scratch building help
guffman990
Post by guffman990 »
Hi everybody
I'm a bit stuck on my dragon kit, I was glueing in the hatches on the upper hull, a few second after glueing in the second hatch I decided to keep it open. So I pulled it off. Unfortunately it's made a mess of the hull and of the hatch :scratch::
I need some advice as if there is anything I can scratch build or buy to cover it. I.e. A tarp or flag..
Re: Scratch building help
if it is still going to be Open ? A figure might obscure some of the area "enough" to distract the viewer!
There are some interesting ones here for ideas only !!!
https://www.aliexpress.com/cheap/cheap- ... els/2.html
Last edited by schweinhund227 on Mon Mar 20, 2017 3:51 pm, edited 1 time in total.
Open the hatch and weather the edges like crazy so it looks like wear and tear usage or maybe even some Battle damage
razzie43
Post by razzie43 »
i glue all the time like that! :)
No serious,remove the hatch use some sharp knife and remove the glue.
After that use tamiya putty or Mr surfacer 500 filler or 1000
Some heavy weathering will also be a nice trick.
Good luck with that!
My collection of tanks :
http://rascarcapaco.blogspot.be/
TheNordus
Post by TheNordus »
With cases like this I just cuss a lot and sand it with a small piece of really, really, really fine sand paper. After you paint over it no one can tell there's a smudge there.
Unless you're entering into a competition, I guess.
-Tommi
Return to “Scratch Building”
