"Zero" chance of any bad puns here....honest.
Post your in progress build threads here
Skullfish
Post by Skullfish »
Bad mistakes...
I've made a few...
Ive had my share of really bad builds but ive come through...
so quite why im building a Zero is anyones guess :wall: i mean, ive seen greenhouses with less glass in them than the canopy on these things! :violin:
"Get on with it" i hear you cry...photos..
contents..not much to see really..but look at that canopy!!
sorry, instructions..
more soon chaps and chapettes.
Jase
On the bench.
Re: "Zero" chance of any bad puns here....honest.
If you've ever wondered what keeps me from Zekes it's the canopy. Bon courage, mon amis.
WorldofPlastic
Post by WorldofPlastic »
Best of luck with it dude ... I'm sure you'll do an Eggcellent Job ;) !!!
Skullfish
Post by Skullfish »
thanks guys, im attempting to use the force.....update shortly as long as my head dosnt eggsplode.
J
On the bench.
Skullfish
Post by Skullfish »
Update:
canopy done thro force of will, stubborness and sending procrastination off to bed with no milk.
black Ultimate primer base, then lightened with a wee bit grey Ultimate primer after fixing some seam issues, then a straight grey Ultimate grey primer to partially modulate.
sorted thro for relevent paints, taking the opportunity to rearrange my bookcases a bit so all the most used stuff is more eggccessible.
aiming to paint base coats later today.
Jase 8-)
On the bench.
Eggxemplary pun!
feeling a little queasy from cheesy pun overload :tongue:
Nice canopy taping job!!
Twokidsnosleep wrote: Wed Apr 05, 2017 5:59 pm feeling a little queasy from cheesy pun overload :tongue:
Oh yes, and that, too. I don't envy you the job of masking that, an accomplishment already to be proud of! One shell of a job, sir.
Lysus wrote: Wed Apr 05, 2017 6:53 pm
Oh dear :roll:
April only has 30 days of puns thankfully
I would also like to add that all should take note the false advertising in the title of this page
Skullfish
Post by Skullfish »
Update
wiping the egg from my face and settling back on my memory foam throne i have made some progress..
Base coats on.
Tamiya XF-66 Light Grey on the belly, XF-70 Dark Green 2 for the shell and upper surfaces, XF-1 Flat Black lightened with XF-23 Light Blue for the cowling, XF-64 Red Brown for the Prop and Spinner.
I then had the smashing 8-) idea to ditch the kit decals in favour of something a bit more be-yolk. :tongue:
In the words of Tony Stark.."throw a little hot rod red in there".
18mm wide Tamiya tape being beaten :tongue: into submission.
Google helped with the flame design, i just adapted to suit my needs. What followed was a scramble :shhh: to get the whole thing wrapped up. :thumb2:
i was starting to crack up at this point :?
the subsequent painting happened thusly...as i forgot to take pics at each stage...sorry
first layer applied was Ultimate white primer as a solid base. next up was Vallejo Air 71.078 Yellow RLM04, trying to fill the flames but leaving the leading edge white hot. Lastly back to Tamiya XF-7 Flat Red as a highlight? touching the edges and tail end of the flames. aiming to give a good flaming effect but in a classic hot rod styley.
Almost at boiling point :hand: now wanting to see whats just under the shell :roll: ....
happy and relieved that things turned out good...so good im going to stop the pun-ishment.. heres half a dozen pics.. :lol:
the underside wasnt spared either.
flying off to the paint booth light eggshell coating.......
Jase
On the bench.
Flaming Zeros are my favourite Zeros
Nice custom work :thumb2:
Skullfish
Post by Skullfish »
Last Update:
ok a quick final coat of aquagloss and the addition of a flying stand and shes done.
good fun build thanks for dropping by.
Jase
On the bench.
Les
Post by Les »
Congratulations on your finished project! :cheers2:
Spook
Post by Spook »
Nicely done, those 🔥🔥🔥flames🔥🔥🔥 are awesome
simon
In the stash
Lots and lots of phantoms
