Viggen Cockpit PE sets
Ultimate delivers a new experience for modellers with a range of products designed and formulated to assist the modern scale modeller.
www.umpretail.com
sheppsea
Post by sheppsea »
Hi,
I just had a quick question regarding the two cockpit PE sets for the Viggen on the Ultimate website (the D/DI and the standard).
I can see the different between the two, but is there any more informaton which one each one is used for? Does one apply specifically to one of the schemes?
Re: Viggen Cockpit PE sets
sheppsea wrote: Wed May 31, 2017 3:42 pm Hi,
There very little difference In them both, I just used the standard one :cheers2:
sheppsea
Post by sheppsea »
Thanks a lot- that was my instinct as well :thumb2:
Edit: having read a bit more there seem to have been two variants - the D and the DI so the PE set must be for those:
https://en.wikipedia.org/wiki/Saab_37_Viggen#Variants
The Tarangus website has a list of every JA 37 produced and whether they are are the D or DI: http://www.tarangus.se/wp-content/uploa ... -List1.pdf
Its strange how its possible to try figure something out over a couple of weeks (on and off) and when you give up you get the answer you want! :)
Return to “Ultimate Modelling Products”
