SkyPainter303's Tamiya 1/20 Benetton Ford B192
Post your in progress build pictures and write ups here
SkyPainter303
Post by SkyPainter303 »
While I take a hiatus from my Corvette build, I've pulled this one out of my stash. It has been many years since I built my only other Tamiya F1 car. I hope I can do this one justice. As complicated as this car seems to be, Tamiya engineering should guarantee a fall-together build. This will be a strictly out-of-box build. I hope the decals hold up despite the kits age of 25 years.
P1040835 by Michael Keogh, on Flickr
P1040836 by Michael Keogh, on Flickr
P1040837 by Michael Keogh, on Flickr
P1040838 by Michael Keogh, on Flickr
P1040839 by Michael Keogh, on Flickr
DrSprue
Re: SkyPainter303's Tamiya 1/20 Benetton Ford B192
Post by DrSprue »
Oh cool, count me in for the journey! :pop:
-Doc
Nice, will follow for sure
I have a few too many of this era of kits in the stash and worry about the decals
Watching with great interest :pop:
SkyPainter303
I wonder how big a pain it would be to paint the green areas.
SkyPainter303 wrote: Mon Jan 22, 2018 5:36 pm I wonder how big a pain it would be to paint the green areas.
You could photocopy the decals and use the copy as a masking guide???
SkyPainter303
Twokidsnosleep wrote: Mon Jan 22, 2018 5:38 pm You could photocopy the decals and use the copy as a masking guide???
Good idea. I actually have a vinyl cutter I could use to make masks.
SkyPainter303 wrote: Mon Jan 22, 2018 5:46 pm
Well there you go, it is a big green swoop. You can definitely do that.
Still, I wanted to see if those decals bailed out on you so I could be prepared :tongue:
DrSprue
Post by DrSprue »
Oh cool stuff. Reminds me of being in an engineering meeting... sharing great concepts! :thumb2:
-Doc
OlaHansson
Post by OlaHansson »
I built thay about 15 years ago...
Havent seen it in 10 years, still packed since I moved 2008.
Looking forward to see yours :)
SkyPainter303
I started the build and after all evening, I still haven't gotten thru step 1. I removed the parts from the tree, cleaned up some seams, and primed with gray Stynylrez. Then using Tamiya acrylics, painted the pieces according to the callouts in the instructions. A lot of masking and paint mixing were required.
As apart of step 1, the first two aero parts are attached. The instructions say to paint these TS47 Chrome Yellow. The were primed, then airbrushed with chrome silver before spraying the chrome yellow from the spray can. Interestingly, these parts are to have green decals applied. If I were so inclined, I would have ordered the correct yellow and green from Zero paints, forgoing the decals.
P1040841 by Michael Keogh, on Flickr
P1040842 by Michael Keogh, on Flickr
Interesting to see how the decals go
Have you found lots of seam lines on your parts???
Man this ‘88 Fujimi kit Ferrari I am doing has seam lines on the edges of every part...you don’t see them all until you are in paint. Driving me nuts
SkyPainter303
I have had some good progress these past two days. The decals seem to be fine and applied them to those rear aero parts. They were a bit fussy to apply and had a good amount of carrier film outlining the color. I used decal solvent to help them conform. After the decals were in place and dry, I trimmed the edges using a fine grit sanding needle. This process did a very small amount of damage. I mixed some Testors acrylic yellow and green to make s few touch ups.
P1040849 by Michael Keogh, on Flickr
P1040850 by Michael Keogh, on Flickr
There are so many parts to this engine and suspension that I am only thru step 2 of the build. There is also a lot of detail painting. The majority of the paints used are Tamiya acrylics and Model Master acrylic used here and there. One thing I wish I had done better were the silver lettering on the cam covers. My Molotow chrome pen flowed a little too well.
P1040851 by Michael Keogh, on Flickr
P1040852 by Michael Keogh, on Flickr
P1040854 by Michael Keogh, on Flickr
P1040855 by Michael Keogh, on Flickr
P1040856 by Michael Keogh, on Flickr
Shunter
Post by Shunter »
Great subject and i have the same fears about the decals i have even though they are in a air tight container. Watching with a keen interest.
pourquoi61
Post by pourquoi61 »
F1, it needs a SIG on its own.
Brilliant choice. :th: :th: :th:
pourquoi61 wrote: Thu Jan 25, 2018 10:53 pm F1, it needs a SIG on its own.
Oh don't start that idea in my head now, damn :think:
Build is coming along nicely, two thumbs up on the engine and rear suspension :thumb1: :th:
Fridgy
Post by Fridgy »
Twokidsnosleep wrote: Thu Jan 25, 2018 11:24 pm
I will sign up for that with my RB6.....
Am i helping??
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
Looking good mate :th:
DrSprue
Post by DrSprue »
Very nice detail! :thumb2:
-Doc
Tay99
Turkmenistan
Post by Tay99 »
Looking good, very similar lay out with the rear suspension on the Ferrari 640 I just finished,
Keep up the great work.
:hi:
pourquoi61
Fridgy wrote: Thu Jan 25, 2018 11:34 pm
Am i helping??
Build a Jones or a Webber car. :idea:
Fridgy
Post by Fridgy »
pourquoi61 wrote: Fri Jan 26, 2018 8:49 pm
Am i helping??
Webber's
Mick
gaz45
Post by gaz45 »
I've been following this build some great work there so far mate :th:
SkyPainter303
Slowly but surely. I primed, painted and assembled the rest of the engine and the cockpit.
P1040868 by Michael Keogh, on Flickr
P1040870 by Michael Keogh, on Flickr
P1040871 by Michael Keogh, on Flickr
P1040872 by Michael Keogh, on Flickr
P1040873 by Michael Keogh, on Flickr
SkyPainter303
Today, I realized that I must order a new set of decals. I have been working on the cockpit tub's paint job. It is now yellow and ready for the green decals. Upon close examination of the decal sheet, it was apparent that the entire sheet was crazed. I had a solution for that in Testor's Decal Bonder. This spray is intended to seal inkjet printed decals so you can soak them in water. It can also be used to repair damaged decal sheets. Normally, this works well, but when I sprayed my sheet, the ink bled into every crazed crack.
Indycals.com sells a replacement sheet, but without the green parts. That is OK, because on those kit decals I can simply cut off the clear carrier film around the edges.
I'll post pictures later.
Shunter
Post by Shunter »
Very nice, you have to love old decals...
DrSprue
Post by DrSprue »
Wow other than old decal issues (yea, thats a scary thing, Im sure) the rest of that build looks awesome! :thumb2: I hope Indycal gets you new ones soon!
-Doc
SkyPainter303
I haven't had much time to work on this build. I do have a small update.
I finished the cockpit build and installation. I also painted the cockpit section yellow. Because the IndyCals decal sheet doesn't include the green or blue areas, I stuck with the kit decals for those painted areas.
As before the yellow is Tamiya spray can TS47.
P1040875 by Michael Keogh, on Flickr
The green is the decal. It has a very subtle alligator texture. Because I am not confident in my masking ability, I am leaving it. The black areas have been brush painted.
P1040876 by Michael Keogh, on Flickr
P1040877 by Michael Keogh, on Flickr
P1040878 by Michael Keogh, on Flickr
Some of these edges are rough and will require touch up. I am hoping for a good color match. I also hope that a clear coat will smooth over any resulting imperfections.
HIghAltitudeScale
Post by HIghAltitudeScale »
Love what you have done with the engine and suspension, great work. Can't wait until you get it all together.
:th:
Cheers,
thetechcowboy.com
Current build;
1/72 Airfix B-17G
1/48 Hobby Boss Bearcat
gaz45
Post by gaz45 »
Looking good nice paint job mate
DrSprue
Post by DrSprue »
Its looking very nice! :thumb2:
-Doc
Coming alive in her colours :thumb2:
