Tamiya 1/20 Team Lotus type 78 1977
Post your in progress build pictures and write ups here
gaz45
Post by gaz45 »
This will be my 3rd entry into this group build, It will be OOB which includes PE and wiring I hope to finish within the time frame.
Image20180320_144738 by Gary Wilcox, on Flickr
Image20180320_144807 by Gary Wilcox, on Flickr
Image20180320_144827 by Gary Wilcox, on Flickr
Image20180320_144905 by Gary Wilcox, on Flickr
Image20180320_144914 by Gary Wilcox, on Flickr
Image20180320_144921 by Gary Wilcox, on Flickr
Image20180320_144927 by Gary Wilcox, on Flickr
Image20180320_145000 by Gary Wilcox, on Flickr
Image20180320_145127 by Gary Wilcox, on Flickr
Image20180320_145135 by Gary Wilcox, on Flickr
Image20180320_145142 by Gary Wilcox, on Flickr
Image20180320_145147 by Gary Wilcox, on Flickr
Image20180320_145220 by Gary Wilcox, on Flickr
For the first time i'm not even going to strip the chrome parts
Image20180320_145349 by Gary Wilcox, on Flickr
Image20180320_145447 by Gary Wilcox, on Flickr
Image20180320_145514 by Gary Wilcox, on Flickr
Image20180320_145526 by Gary Wilcox, on Flickr
Image20180320_145546 by Gary Wilcox, on Flickr
Image20180320_145648 by Gary Wilcox, on Flickr
Image20180320_145700 by Gary Wilcox, on Flickr
Image20180320_145710 by Gary Wilcox, on Flickr
Image20180320_145716 by Gary Wilcox, on Flickr
Image20180320_145724 by Gary Wilcox, on Flickr
Image20180320_145732 by Gary Wilcox, on Flickr
Image20180320_145738 by Gary Wilcox, on Flickr
Image20180320_145745 by Gary Wilcox, on Flickr
I hope i have not taken on too much.
gaz45
Re: Tamiya 1/20 Team Lotus type 78 1977
Post by gaz45 »
The history part.
The Lotus 78 'wing car' was a Formula One racing car used in the 1977 and 1978 seasons. It was designed by Peter Wright, Colin Chapman, Martin Ogilvie and Tony Rudd, and was the car that started the ground effect revolution in Formula One.
Category Formula One
Constructor Team Lotus
Designer(s) Peter Wright
Colin Chapman
Martin Ogilvie
Tony Rudd
Ralph Bellamy
Predecessor Lotus 77
Successor Lotus 79
Technical specifications[1]
Chassis Aluminium monocoque
Suspension (front) Double wishbone, inboard spring/damper
Suspension (rear) Parallel top links, lower wishbones, twin radius arms, outboard spring/damper
Axle track Front: 1,702 mm (67.0 in)
Rear: 1,600 mm (63 in)
Wheelbase 2,741 mm (107.9 in)
Engine Ford-Cosworth DFV, 2,993 cc (182.6 cu in), V8, naturally aspirated, mid-engined, longitudinally mounted
Transmission Hewland FG400 5-speed manual
Weight 588 kg (1,296.3 lb)
Fuel Valvoline
Tyres Goodyear
Competition history
Notable entrants John Player Team Lotus,
Rebaque
Notable drivers
 Mario Andretti
 Gunnar Nilsson
 Ronnie Peterson
 Héctor Rebaque
Debut 1977 Argentine Grand Prix
Races
Wins
Podiums
Poles
F.Laps
33
7
11
9
7
Constructors' Championships 1 (1978)
Drivers' Championships 1 (Mario Andretti, 19
In early 1976, spurred on by the disappointing lack of pace of the ageing Lotus 72 the previous season, and the indifferent performance of the current Lotus 77, Chapman wrote a 27-page document detailing his ideas on low drag air penetration. After he had studied a de Havilland Mosquito fighter bomber, he paid close attention to its wing mounted radiators, and the hot air outlets that were designed to induce lift. Chapman realised that such a system inverted could give significant downforce. Careful examination of Bernoulli's principle of fluid dynamics confirmed his thoughts on the effects of an upturned aeroplane wing profile fitted to the car, and gave the document to his head of engineering Tony Rudd.
Rudd appointed a team to work on the project: chief designer Ralph Bellamy, vehicle engineer Martin Ogilvie and aerodynamicist Peter Wright. Rudd and Wright had previously worked for BRM, and before joining Lotus in 1970 had done a design study into the possibility of an inverted wing profile fitted to one of their cars. Rudd had tested a number of scale models, but lack of the right testing methods and BRM's declining fortunes meant development had never got beyond the experimental stage. However, Wright remembered their work and brought it into the project.
Wright then set about experimenting with F1 car body shapes using a wind tunnel and a rolling road, when by happy accident he began to get remarkable results in one of the models. Closer inspection found that as the rolling road's speed increased, the shaped underbody was being drawn closer to the surface of the road. Wright experimented with pieces of cardboard attached to the side of the model car body, and the level of perceived downforce produced was phenomenal. The results were presented to Colin Chapman, who gave the team free rein to come up with an F1 chassis design.
After a round of design sketches and engineering drawings, and further work in the wind tunnel at Imperial College the car was put into production. Five examples were built, codenamed John Player Special Mk. III, otherwise known as the Lotus 78 which appeared in July 1976. Mario Andretti wanted to introduce the car early, possibly at the Dutch Grand Prix that year but was overruled by Chapman, as he didn't want other teams discovering what Lotus had achieved.
The 78 was introduced at the first race of 1977, and proved to be the class car of the field that season, winning five races. The car proved relatively easy to set up and modify, with particular attention paid to the undercar aerodynamics and their interaction with the track surface, hence a stiffer suspension design which was required to maintain the aerodynamic effects.
Development
The 78 was loosely based on the Lotus 72, sharing the same basic wedge shape and internal layout, but featuring detailed aerodynamic improvements, better weight distribution and a longer wheelbase. It had a slimmer, stronger monocoque made from aluminium sheet and honeycomb, which was developed from the 77. The bodywork was made up of fibreglassbody panels with aluminium used to strengthen the chassis at points. The car created quite a stir when it first appeared, and outwardly seemed ahead of its time. Internally of course, it was a quantum leap ahead. Andretti worked hard with the car, testing for many thousands of miles at the Lotus test track in Hethel.
Based on Bernoulli's discoveries, the underside of the sidepods were shaped as inverted aerofoils, in the same vein as conventional wings but on a much larger scale. Wright and Chapman had discovered that by shaping the floor of the car in this way, they could accelerate the air passing through the gap between the ground and the underside, thereby reducing the air pressure under the car relative to that over it. This created a partial vacuum, effectively sucking the vehicle down which forced the tyres harder onto the track.
Copying the Mosquito's radiator design, the radiators were positioned so that the hot air escaping would pass over the upper bodywork of the car, creating even more downforce. To make the suction effect as great as possible, the monocoque was slimmer, forcing the air passing through between the ground and the inverted wing shape cover as much as possible.
The greater force downwards on the tyres gave more grip and thus higher cornering speeds. This ground effect had the great advantage of being a low drag solution unlike conventional wings, meaning that the increased cornering ability was not compromised by a decrease in straight-line speed. If anything, because of the decreased air resistance, the top speed of the car also increased accordingly.
To begin with, brushes were fitted to the base of each sidepod to keep the low pressure area under the car. When these proved insufficient, Lotus tried plastic skirts, but these abraded very quickly, until finally moveable rubber skirts were developed which proved very effective. The sliding skirts sealed the gap between the sides of the cars and the ground and prevented excessive air being sucked into the low pressure area under the car and dissipating the ground effect. Andretti described driving the 78 as if it were 'painted to the road'.
Lotus 78 in an exhibition
The fuel tanks were three separate cells, with one behind the driver and one each in the midsection of each sidepod. The sidepod tanks could be controlled from the cockpit by the driver and could be used to fuel the engine separately or together, improving performance and weight bias in cornering. The suspension set up from the previous Lotus 77 was used, with the suspension designed for quick changes in geometry. This helped set the car up for a specific circuit when required.
Unfortunately after first tests were done, the low pressure area under the car was found to be too far forward, requiring a very large rear wing to be designed resulting in a lot of drag at high speeds. This was especially noticeable on fast tracks such as Hockenheim and the Österreichring, where the Ferraris and McLarens were much faster than the 78. To compensate, Ford provided development versions of the Ford Cosworth DFV, increasing the car's speed but also sacrificing reliability. Andretti had no fewer than five engine failures in 1977, costing him the world championship to Niki Lauda, even though he had won four races and taken six pole positions to Lauda's three wins. Eventually a smaller wing was designed in time for the Italian Grand Prix (see above picture), which cut the drag factor significantly, and allowed Andretti to take a popular 'home' victory.
Another problem was with the rear suspension, which although slightly modified to allow clearer airflow from the rear of the sidepods, it was still directly in the path of the exiting air, which affected the stability of the back of the car, causing oversteer.
Racing history
Héctor Rebaque's Lotus 78 at the 1979 British Grand Prix, where it was used as a spare car.
It was obvious that the 78 was something special though, as proved by Andretti and Gunnar Nilsson who won once in Belgium. When the car worked well it was almost uncatchable. Other teams started scrambling to design their own version for 1978. The problem they had was that they didn't know exactly what was so special about the car, as Chapman and other members of Lotus came up with any number of excuses to hide the real reason. That as well as the skirts, which hid any view of the underside of the car.
The 78 was good enough to still be a winner in early 1978, with Andretti and Ronnie Peterson scoring a win each and another three pole positions before it was replaced by the Lotus 79, which was as far ahead of the 78 as the 78 had been ahead of the rest of the field in 1977.
The 78 was to see one further works team start, however. Owing to damage sustained to his 79 in practice, Ronnie Peterson was forced to use the reserve car, 78/3 (JPS-17), to qualify for the 1978 Italian Grand Prix. The car had not been maintained or developed by the team as they concentrated on the 79, and the car was hurriedly prepared for the race. Although his team mate Andretti predictably took pole position, the slower 78 was only good enough for fifth place on the grid for Peterson. Sadly, the Swede was caught up in a massive start line accident, which resulted in his car ramming the barriers nose-first, completely destroying the front end of the vehicle. Peterson later died owing to complications arising from the treatment he received following the crash.
The original development prototype, 78/1 (JPS-15), was sold to Héctor Rebaque. He ran this car through his Rebaque privateer team in World Championship events during 1978 and 1979, and in non-Championship races into the early 1980s.
In all, the Lotus 78 took seven wins, nine pole positions and scored 106 points in its career.
gaz45
Post by gaz45 »
Time to start this build
To start with i have made up the engine, gearbox and rear suspension.
Image20180320_155948 by Gary Wilcox, on Flickr
Image20180320_170335 by Gary Wilcox, on Flickr
Image20180320_231125 by Gary Wilcox, on Flickr
Image20180321_215939 by Gary Wilcox, on Flickr
Image20180321_215915 by Gary Wilcox, on Flickr
Image20180321_215857 by Gary Wilcox, on Flickr
Image20180321_215842 by Gary Wilcox, on Flickr
Image20180321_215828 by Gary Wilcox, on Flickr
Image20180327_144623 by Gary Wilcox, on Flickr
Image20180327_144558 by Gary Wilcox, on Flickr
Image20180322_212633 by Gary Wilcox, on Flickr
Image20180322_220628 by Gary Wilcox, on Flickr
Image20180322_220643 by Gary Wilcox, on Flickr
Image20180322_220655 by Gary Wilcox, on Flickr
Image20180322_220718 by Gary Wilcox, on Flickr
Image20180327_211752 by Gary Wilcox, on Flickr
Image20180327_211803 by Gary Wilcox, on Flickr
Image20180327_211819 by Gary Wilcox, on Flickr
The paints used so far are Ultimate gloss black primer, AK Xtreme metal polished aluminium, Tamiya X-11 chrome silver, X-10 gun metal, X-18 semi gloss black, X-1 black, XF-56 metallic grey, X-7 red and XF-5 flat green.
So far it has gone together well the exhausts were a bit fiddly to get right.
Ya well, you just better not finish it off before I finish my 79
Jeeze slow down a touch ;)
Just joshing :D , engine work looks great, top notch :thumb2:
Johnj
Post by Johnj »
Looking good gaz. I thought it was 1/12 scale with all the detail on it. Is it a new release kit ?
gaz45
Post by gaz45 »
Twokidsnosleep wrote: Wed Mar 28, 2018 3:50 pm Ya well, you just better not finish it off before I finish my 79
Cheers Scott you will finish before me mate and ill never be on a level with your work
gaz45
Post by gaz45 »
Johnj wrote: Wed Mar 28, 2018 5:03 pm Looking good gaz. I thought it was 1/12 scale with all the detail on it. Is it a new release kit ?
It's a 2011 release kit mate
gaz45 wrote: Wed Mar 28, 2018 11:37 pm
Oh I don't know about that...you build some sweet stuff mate :thumb2:
NorthernModeller
Post by NorthernModeller »
Great work so far mate :) hopefully get it finished before the end :D
gaz45
Post by gaz45 »
Right i have made quite a bit of progress since my last post
The front suspension and hubs painted and assembled.
Image20180403_172811 by Gary Wilcox, on Flickr
The radiators and cockpit tub also ready.
Image20180403_225458 by Gary Wilcox, on Flickr
Image20180403_233037 by Gary Wilcox, on Flickr
Image20180403_233048 by Gary Wilcox, on Flickr
Image20180403_233104 by Gary Wilcox, on Flickr
Image20180403_233121_HDR by Gary Wilcox, on Flickr
Image20180403_233146 by Gary Wilcox, on Flickr
The engine is now in place along woth the front wheel hubs and here there is a metal rod for the steering.
Image20180403_233207_HDR by Gary Wilcox, on Flickr
Image20180403_233235_HDR by Gary Wilcox, on Flickr
Image20180403_233247_HDR by Gary Wilcox, on Flickr
A couple of the decals are on at this stage for ease of access before the sides ar put in place.
Image20180406_183143 by Gary Wilcox, on Flickr
The seat, dials and the steering wheel painted and decaled up ready for fitting.
Image20180406_183226 by Gary Wilcox, on Flickr
Image20180407_221807 by Gary Wilcox, on Flickr
Image20180407_222543 by Gary Wilcox, on Flickr
and finally the rear wing, the cockpit fairing and induction box assembled and reay for some primer and paint.
Image20180409_001254 by Gary Wilcox, on Flickr
The paints used in this section are Zero paints Lotus F1 black, AK Xtreme metal aluminum, Tamiya XF-1 flat black, X-18 semi gloss black, X-7 red.
Thanks for taking the time to look and to comment.
Looking good :thumb1: :th:
She is a black beauty that one!
gaz45
Post by gaz45 »
Cheers Scott
gaz45
Post by gaz45 »
So the final strech
The wheels painted in Tamiya titan gold.
Image20180411_122813 by Gary Wilcox, on Flickr
Image20180411_122838 by Gary Wilcox, on Flickr
Wheels now on and time to finish the decals
Image20180411_142032 by Gary Wilcox, on Flickr
Image20180411_142106 by Gary Wilcox, on Flickr
The decals went on well with the exception of one of the number 5's so that one is missing.
Image20180417_161811 by Gary Wilcox, on Flickr
Image20180417_170930 by Gary Wilcox, on Flickr
Here we are all finished.
Image20180419_140515 by Gary Wilcox, on Flickr
Image20180419_140524 by Gary Wilcox, on Flickr
Image20180419_140532 by Gary Wilcox, on Flickr
Image20180419_140541 by Gary Wilcox, on Flickr
Image20180419_140557 by Gary Wilcox, on Flickr
Image20180419_140616 by Gary Wilcox, on Flickr
Thanks for taking a look and for your comments
I will post some pic's in the reveal section.
