Academy 1:72 AH-64D Apache
Post your build progress here :)
I recently watched an excellent documentary on Netflix called Apache Warrior. It told the tale of an attack on Iraqi targets at the start of the conflict.
My entry will be a tribute to these wonderful machines it isn't anything political to do with the conflict in Iraq. Any of that non-sense popping up in this thread will be removed. I haven't decided on the livery yet depends on what aftermarket I can find.
Here is the box.
The kit is small at 1:72 which will be challenging for me. But at least it will fit in the spray booth! There are two main sprues with only a couple additional smaller sprues.
I have found a suitable aftermarket decal set!
I will be using the "19" scheme which is for the 6-6 Cav as flown on the Karbala Attack (which is what the documentary above is about). Super-happy that I found exactly what I wanted.
I also picked up a mask set and some colored PE for the pit!
Re: Academy 1:72 AH-64D Apache
I love the Apache - there's definitely something about the menacing silhouette that leaves you in no doubt that you are in serious trouble if you're on the receiving end.
Looking forward to seeing how this builds up and adding another kit to the "seriously no more new kits list" :whistle:
jmurphy18
Post by jmurphy18 »
Very cool Apache build :th:
John M
Quax
Greenland
Post by Quax »
Looking forward to following your build Matthew! :banana:
A mess as usual...
Cool project :banana: :banana: :banana:
:heli:
Looking forward to this one, best of luck with the build mate :th:
The Apache is definitely one of the new iconic aircraft of the modern era.....doesn't it look truly dangerous.. :th: :cheers2:
Major General
Major General
Looking forward to this.
I really like the Apache, its got that nasty brutal functional look about it. And it always looks dirty.
Stokesy44 wrote: Tue Dec 03, 2019 9:39 am Looking forward to this.
Yes you see one of these suckers coming towards you and your first thought wouldn't be it's coming over for a friendly chat.... :wtf:
I was able to grab a few images from the documentary to show the kind of damage these aircraft were able to survive.
And no, I won't be attempting that!
bfrd wrote: Tue Dec 03, 2019 11:44 am I was able to grab a few images from the documentary to show the kind of damage these aircraft were able to survive.
That's pretty cool.... :th: :cheers2:
Donkeywalloper
Post by Donkeywalloper »
I fancied having a go at one of these roundy, roundy, winged things.
This looks a splendid little project chap :banana: .
Shall pull up the :pop: and prepare to be amazed.
DW
Bench:1/35 HobbyBoss Nagmachon with oodles of Aftermarket
Shelf: Lots (82 Kits of multiple scales) of Armour + couple of Flappy / Wing Things, found a KV2 95% built and primed four years ago. Plus a few Lego Tech kits, to help restore MoJo
jmurphy18
Post by jmurphy18 »
I was working at a base where the were stationed and got to watch them in action when I would go out the airfield to do a job. They are awesome.
John M
TommyKillander
Post by TommyKillander »
Excellent choice! :D
Good luck with the build!
Tommy
Got the detail set and masks. Can finally get started!
I had a watch of the Netflix docu you mentioned.
These kind of shows make me mad when I see the stupidity of military minds that put lives and equipment in danger.
Adaptation to a situation might be a good objective next time. Flying through a shitstorm of variety of arms whilst low to the ground is not wise. Then turning around and doing it again to go back to an unprepared rendezvous site is even stupider.
At the very least, I would have been lawn mowing my way back with every weapon at my disposal; Shoot at everything, clear a path, make them run for cover and their f’ing lives.
But then they are not allowed indiscriminate fire...which is BS when you are getting that from your enemy.
Amazing that those birds took all that damage and got everyone back safely. Amazing.
Twokidsnosleep wrote: Sun Dec 08, 2019 7:46 am I had a watch of the Netflix docu you mentioned.
:crazy: :crazy: ......... :th: :th: :cheers2:
I got some of the cockpit put together. The PE requires that the molded detail be carved off.
Just about everything is painted NATO black.
The pre-painted PE looks great.
yeah I'm a big fan of the pre painted PE, fantastic stuff.
:th: :cheers2:
jmurphy18
Post by jmurphy18 »
Sweet, the cockpit and PE look awesome
John M
TommyKillander
Great stuff! :th:
Tommy
Quax
Greenland
Post by Quax »
Looks great so far Matthew and a little familiar... :think: the pe certainly looks the part :th:
A mess as usual...
Lovely work on the cockpit Matthew :clap:
I got a little more PE work done. Below is a start to finish transformation. I had to remove a little bit of the plastic detail.
There is a PE replacement for the removed detail. It was on the tweezers then it wasn't. Looks like I will be scratch building that.
Donkeywalloper
Very nice work Matthew.
DW
bfrd wrote: Fri Dec 13, 2019 11:33 am <snipped>
There are times - noteably a lot in the last couple of days when I'd swear the best way to build the fine details is in one of those funny cabinets medical places use where you put your arms in through sealed openings. The wife is getting a bit tired of frantic cries of "Grab the dog - I've lost a bit!!" :lol: :lol:
The PE does make it look good though - well done!
    Hobby Boss 1/350 Surcouf
    Mikro Mir 1/350 HMS M1
    jmurphy18
    Post by jmurphy18 »
    Awesome looking work on this. :th:
    John M
    I am still waiting on getting the decal sheet in before I move to paint any of the exteriors. I don't think the decal sheet has any paint recommendations, but I don't want to risk it. The kit callouts are all over the place. I know my color utility isn't perfect, but I do think it gives a fairly accurate idea. Here is a screen grab using some of the kit suggestions on the paint color.
    Obviously, Testors is out. Taking that range out the rest are fairly close. I think I might try Mission Models as the LHS just started carrying those in stock.
    @Quax What color did you go with?
    Quax
    Greenland
    Post by Quax »
    bfrd wrote: Mon Dec 16, 2019 12:23 pm @Quax What color did you go with?
    The kit callout for mine is 60% Olive drab with 40% flat black, as I know that whenever they fly over my house (noisy b*****ds) they look black so its probably not far out. I think I'll mix it like this and see what I think when its on, I can always lighten post shade.
    A mess as usual...
    Finally picked this one back up. Got the fuselage halves together and a bit more PE.
    Added more PE to the ordinance.
    Attached the engines.
    This is kinda like a tank in the sense that it will practically be fully built and then painted. That is a little weird for me, but we will see how it goes.
    Pe is working the kit nicely.
    :th: :cheers2:
    One step forward several steps back.
    First off let me say the I have been impressed with the overall fit of the parts. However, there are exceptions. The very front of the fuselage has a large gap. This will require some filler and elbow grease.
    Also while attaching some of the greeblies I snapped off one of the wheels from the front landing gear. Instead of trying to glue the part back together I just snipped off the other one as well.
    I decided to use the tips from my syringes as a replacement.
    First I heated up the tube with a heat gun and melted the ends of the gear struts.
    I then cleaned up the joints to fit the tube.
    Next, I used a diamond coated cutoff wheel to cut down the tubes. I should have been wearing safety glasses as one of the small tube pieces hit me in the face.
    All that remains is to CA glue the tubes in place.
    I will glue the wheels on after paint.
    As an added bonus I accidentally burned the tail with heat gun. Fun!
    OOoooo battle damage.....Well done or medium rare?
    Love the mod of the landing gear, it will look and function better
    alextheblue
    Post by alextheblue »
    Gotta agree, the landing gear looks really good!! Plus, all your patience with the PE is really going to pay off.
    Heat gun!! Styrene!! Arrgghhh!!! :o :wall: Like ,Scott says - battle damage! :th: :th: :cheers2: :cheers2:
    www.alextheblue.com
    Workshop field modification for fast left hand turns :whistle:
    Got a little worse later in the day. The "glass" doesn't come out very well. IMO it is a terrible design. While trying to get the glass out after a test fit I broke off one of the new landing gear arms. In the same maneuver, I broke off off a handhold and pitot tube. @Twokidsnosleep talked me out of Hulk Smashing and I drilled out a smaller hole in the gear arm and corresponding tube for a wire to help refasten. I can drill out the holes for the handhold and use a spare or make one from a wire. The pitot tube may just stay off. The heat gun damage is filled. I lost a bit of detail in the tail but at this point, I really couldn't care less.
    Oh shite this thing is really fighting you
    Keep battling, it will work out :thumb2:
    Matt what a struggle you're having mate :wall: The PE looks great though :th:
    Stick at it mate you'll get there :th:
    Donkeywalloper
    Crumbs Matt you're having a right old battle with this thing.
    Its an interesting build though chap and it will eventually look awesome, I'm sure.
    Look after yourself,
    DW
    Quax
    Greenland
    Post by Quax »
    yes definitely keep going, I'm glad 2KNS talked you out of the stamp manoeuvre!
    Its going to look great with all the pe once you get the paint on :thumb1:
    A mess as usual...
    Grabbed a few pics this morning of the re-repair to the gear arms.
    I plan to use a stiff wire with a 90-degree bend to insert into the open end of the tube. I drilled out an appropriate hole in the back of the wheels
    Just to make myself feel a little better I popped on the rotors to give it a look-see.
    jmurphy18
    Post by jmurphy18 »
    I like your mods, nice work!
    John M
    Commiserations on having to fight the fight with this one. If its any help - the photos thus far are looking really good. The PE work really helps it.
      Thanks for all the support.
      I got some paint down this evening. It looks black, but is really a very dark green.
      Cool!👍🏻😎😍
      Great work sticking with sorting the issues out on this one (kit-inflicted & self-inflicted) as the results so far look great - the PE work all adds a superb level of refinement.
      Stick with it - it's looking great :cheers2:
      I can see your getting on top of it as it is coming together nicely albeit begrudgingly. :th: :th: :cheers2:
      Ok, Scott keeps telling me to keep my mistakes to myself. I am not listening because I am stubborn and stupid...
      In a momentary lack of mental faculties, I decided to not prime the helicopter. I wanted to be done and skipped a step. That was not the step to skip. Paint adhesion is terrible. I love the paint, MMP is spraying and covering very well (it doesn't even smell). I think the lack of a primer coat is to blame. So, in order to try and offer some protection to the paint, I gave the model a couple of coats of Alcad II Aquagloss. I do not trust the paint holding up during the decal process. The aftermarket decals are from Print Scale and they do not look very good. I will only use the ones I absolutely have to use in order to make the correct markings. Other than that I will be using the kit decals (Cartograf and look excellent).
      Until my next boneheaded move!
