ElCapitan's Airfix 1/72 Chinook HC1
Post your build progress here :)
ElCapitan
Post by ElCapitan »
Decided to join in with this SIG as I found this kit on ebay. I've been looking for it for a while and haven't had much luck!
My uncle flew these for years, and as a child I had the pleasure of sitting in the cockpit of one at RAF Odiham while it still had the pictured camo pattern. I remember being extremely jealous of my brother who got to climb up onto the roof! I also have fond memories of the low-level flybys we got whenever he was flying up to Leuchars or Lossie. Shame we didn't have camera phones in those days!!
ElCapitan
Quax
Greenland
Re: ElCapitan's Airfix 1/72 Chinook HC1
Post by Quax »
Welcome aboard Rob, I live on the Wallop\Odious flightpath and one regularly comes over at 200ft at 2300, they're either practicing night insertions or trying to get back before the naafi closes....
A mess as usual...
TommyKillander
Post by TommyKillander »
Great choice! :thumb1:
Good luck with the build! :)
Tommy
Welcome to the SIG Rob! Great to have you onboard :cheers2:
And another iconic silhouette & sound!
Good to have you on board Rob :th: good luck with the build mate :th:
Look forward to it :thumb2:
Build away
ElCapitan
Post by ElCapitan »
Aaand we're started!
Nice top-opening box with one bag of sprues in it. The moulding looks pretty good - nice engraved detail and minimal flash. Decals look like they'll be OK.
I made a start by building up the cockpit. I'll paint it all in situ apart from the instrument panel, which will be easier to paint separately.
There were some window frames to put in, which didn't exactly fit very well...
I'll put some plastic putty in the gap later.
ElCapitan
Great to see you're under way Rob and it's got that classic airfix "fit" :)
ElCapitan
Post by ElCapitan »
I've not been getting as much free time as I'd have liked to recently, but managed to do some work on this yesterday.
Painted the cockpit and put the 2 fuselage halves together. No dramas here but quite difficult to hold the fuselage together as they only join at the top. The bottom is a separate piece that will be added later.
ElCapitan
Coming along nicely Rob :th:
ElCapitan
Post by ElCapitan »
I've had to leave modelling on the backburner recently, so not progressing as quickly as I'd have liked with this. Managed to do some work on it last night. Mostly filling and sanding unfortunately - almost every join on this kit needs filler! I also built up the engines and glued all the windows in place. The clear parts are so thick they don't sit flush with the fuselage :wall: I'm not sure what I can do about that though, as I'm not going to start sanding clear parts.
I did do a little test though to see if it's true that TET cannot be used with clear parts - I used it on all these parts and there were no adverse effects.
ElCapitan
ElCapitan
Post by ElCapitan »
Almost ready for priming. Just need to finish masking the windows and we'll be there.
ElCapitan
alextheblue
Post by alextheblue »
Love the Chinook - you can't beat the WHOMP! WHOMP! WHOMP! of those twin rotors!
You're doing a cracking job on a challenging kit Rob. Definitely watching this one!! :th: :th: :cheers2: :cheers2: :pop: :pop:
www.alextheblue.com
Expressing my ignorance here and will ask what are all those protrusions down the left side of the fuselage ?............aerial supports ? Seems to be too many for that.
:thumb2: :thumb2: She's starting to look the part and very nice work :thumb2: :thumb2:
ElCapitan
Post by ElCapitan »
digger303 wrote: Sat Mar 07, 2020 11:52 pm Expressing my ignorance here and will ask what are all those protrusions down the left side of the fuselage ?............aerial supports ? Seems to be too many for that.
They're for the HF antenna. I'll use some rigging wire for it.
ElCapitan
Usual Airfix fit issues I see even though it's an Italeri rebox of the late 90's. You got it all in hand mate :th:
Donkeywalloper
Post by Donkeywalloper »
alextheblue wrote: Sat Mar 07, 2020 6:50 pm Love the Chinook - you can't beat the WHOMP! WHOMP! WHOMP! of those twin rotors!
They were always referred to in the Army as Whocka, Whock due to the distinctive rotor noise. They are unmistakable (like a Merlin).
Its always to an Ex-Infantry lad a unique sound that on a few Exercises meant End-Ex (End of Exercise), as a Chinook picked you up from the middle of nowhere. I also have been dropped off (literally once, with all my kit, Bergen and a Gimpy and Face-Planted into wet mud from a couple of feet up) from the ramp, into God knows what.
An amazing build and this is gonna look truly awesome when finished.
DW
Bench:1/35 HobbyBoss Nagmachon with oodles of Aftermarket
Shelf: Lots (82 Kits of multiple scales) of Armour + couple of Flappy / Wing Things, found a KV2 95% built and primed four years ago. Plus a few Lego Tech kits, to help restore MoJo
ElCapitan
Post by ElCapitan »
Thanks for all the comments!
I'm going to remove some of the antenna supports actually, as the configuration doesn't match an HC.1, from what I can tell from photos. I won't be able to match completely, but It'll be closer.
Also the winch above the side door shouldn't be there, and it looks garbage, so I'll get rid of that too.
ElCapitan
Had a couple of these Thwocka over the top of me yesterday - love that distinctive sound.
This is coming along nicely Rob, hopefully you'll get enough bench time to get it in paint by the end of the month but I know that's easier said than done sometimes! :cheers2:
ElCapitan
Post by ElCapitan »
Tomcat64 wrote: Wed Mar 11, 2020 11:07 am Had a couple of these Thwocka over the top of me yesterday - love that distinctive sound.
I think once it's had a base coat then I'll be able to do the rest in front of the TV - that'll be the brush-painted disruption pattern, decals, some weathering and varnish which I usually brush on anyway. Fingers crossed I can get all that done.
ElCapitan
ElCapitan
Post by ElCapitan »
Working from home now, which gave me a bit of time to get this in primer. I'm happy with how it's looking. Most seams are invisible, and I can live with the ones which aren't.
ElCapitan
AirCadet424
Post by AirCadet424 »
Nice work Rob, looking good and the paintwork looks nice and smooth. I have a Chinook on my wishlist, though probably gonna be 1:48 and likely the Italeri kit? Just keeping my eye open on a certain auction site ready to add it to my ever growing stash!
Will be following your build, keep up the good work.
Per Ardua Ad Astra
Quax
Greenland
Post by Quax »
Good stuff Rob all the work on the clear bits has paid dividends!
A mess as usual...
Lovely primer there Rob :th:
Can't wait until you get the masking off the windows. :th: :cheers2:
ElCapitan
Post by ElCapitan »
Hopefully will get to the unmasking stage soon. I managed to get the base coat of Desert Pink on yesterday.
Now I think I'll move onto this silly camouflage nonsense before masking and painting the black on the underside, rotors and anti-glare.
ElCapitan
ElCapitan
Post by ElCapitan »
Really pleased with the effect I'm getting brushing on Tamiya XF-1 till the brush is totally empty.
ElCapitan
Nice top colour Rob, that cammo looks good, but what a task :crazy: :th:
ElCapitan
Post by ElCapitan »
Kevthemodeller wrote: Thu Mar 26, 2020 1:44 pm Nice top colour Rob, that cammo looks good, but what a task :crazy: :th:
Thanks! It's actually easier and quicker than I thought it would be - I've just finished one side already:
I'm happy with how it's looking!
ElCapitan
Looks great Rob :th:
ElCapitan
Post by ElCapitan »
Almost done with painting the fuselage - most details are done; only the underside still to do.
ElCapitan
Oh yes, the cammo is superb :clap:
That must have been a nightmare to paint!! Well done sir!! :cheers2:
    Hobby Boss 1/350 Surcouf
    Mikro Mir 1/350 HMS M1
    Splendid brush work :clap: :clap: :cheers2:
    Superb work with the camo Rob - I don't think I've seen one like that before - cracking job :clap: :clap: :clap:
    If you haven't seen it already I'm leaving the SIG open for a while longer so people can get stuff finished without having to rush :cheers2:
    ElCapitan
    Post by ElCapitan »
    Tomcat64 wrote: Sun Mar 29, 2020 1:58 pm Superb work with the camo Rob - I don't think I've seen one like that before - cracking job :clap: :clap: :clap:
    Awesome! I might get this finished then! Is there a date in mind, or is it undetermined (such is life atm).
    ElCapitan
    ElCapitan wrote: Sun Mar 29, 2020 4:46 pm Awesome! I might get this finished then! Is there a date in mind, or is it undetermined (such is life atm).
    My original thought was to leave it open until lock down is eased, but will probably leave it undetermined for now and as long as people are posting updates I'll keep it open.
    If it goes quiet for a couple of weeks then I'll put up a notice and see if there are any last takers.
    Hope that makes sense :cheers2:
    ElCapitan
    Post by ElCapitan »
    Edging this closer to completion. The last few days I've done the decals (with the help of my 4 year old son, when I needed 3 hands), I gave the whole thing a light dry-stippling of Vallejo Medium Grey to fade it all a bit and give it more of a dusty look, then gave it a coat of Testors dullcote and unmasked the windows. Now just need to do the wheels, rotors, wipers, antennae and maybe some sandy pigment if I can get my hands on some.
    ElCapitan
    That camo really hides a lot of detail, but I like it a lot. :th: :cheers2:
    CygnusX1
    Post by CygnusX1 »
    That looks great. That camo from the ODS era? Looks sorta like it. I think this is going to look fantastic when it's done.
    :thumb2: All looks good to me and nice work :thumb2:
    ElCapitan
    Post by ElCapitan »
    CygnusX1 wrote: Thu Apr 02, 2020 1:20 am That looks great. That camo from the ODS era? Looks sorta like it. I think this is going to look fantastic when it's done.
    That's right. The chinook wore this camo during special forces operations in the first Gulf War. I got to see them in the hangar shortly after their return to the UK, and they hadn't been repainted yet.
    ElCapitan
    Just keeps getting better Rob :th:
    Yep the lads have already said it but that's coming together really nicely Rob - cracking work :th:
    Donkeywalloper
    That has to take the top marks for Camo. Thats a Wow and a :bow::
    DW
    Hi Rob, If you're still working on this one I've decided to close down the SIG for the end of July. Would be great to see your Chinook in the reveal section if you get chance, but obviously don't rush it now you've got this far :cheers2:
