ICM G4 the car for the german military toffs
The origins of this interesting car.
As World War II broke out toward the end of the 1930s, Mercedes-Benz produced all kinds of vehicles for the war, namely trucks. However, German dictator Adolf Hitler had a unique request; he wanted to parade around in a Mercedes-Benz.
As a result, the carmaker came up with an open-top armored off-roading truck which six wheels. According to Autoevolution, it’s called the W31 Type G4, and it unsurprisingly started as a truck. However, the custom-built machine even featured a folding front seat so the dictator could stand during parades.
Mercedes-Benz built 57 examples of the W31 Type G4. Following the end of World War II, the allied forces destroyed most of the surviving trucks. As a result, Daimler estimates that only three of the remaining trucks are fully original. Additionally, since these have historical significance, at least one of the surviving trucks lives in a museum in California.
According to Autoevolution, the Type G4 was quite an imposing vehicle. This Mercedes-Benz is 6.2 ft high and almost 20 ft long thanks to its many wheels. Under the hood you got various engine choices. However, the most powerful option was a 5.2-liter inline-eight which produced 115 hp.
While we don’t know exactly how heavy this truck is, 115 hp means it certainly isn’t quick. That’s because the main purpose of this vehicle was to parade the dictator around and allow his supporters to see him.
With just three surviving examples of this ultra-rare Mercedes-Benz out there, they don’t come up for sale very often. In fact, one of the last times these trucks sold was back in 2009. Back then, Autoblog reported that three examples were offered as a set for $9 million.
On with the kit and you would have noticed the chrome and the amount of shine this requires....what a head bender.
First off is the wheels as they seem the easiest thing to start with and straight off ran into a small problem.
There is a gap where the two side wall part fits into the main tyre and it sits too high. Easy to fix with some sanding and spue goo.
The engine goes together like clock work except for seam lines to be removed which are on at least half the parts so far.
The other piece ( part of suspension) which isn't put together particularly well was a right pain. 9 parts and all smaller than my 2 fat thumbs could handle.The good point is they fit well....mostly. The glue points are a bit loose on the larger locating points.
:th: :th: :th: :cheers2:
PS.... A very BIG thank you to all those who put this on the bench for the next 3 months :wtf: ............. :lol:
Re: ICM G4 the car for the german military toffs
Ya you will be fine
No wings to have to add rigging to…not like a sailing ship some others are stuck with
Looks an interesting build.... I wouldn't mind adding this to the stash when normality returns. Will be following this with interest!! :)
    Tamiya 1/35 Joseph Stalin 3
    likes Scott says :banana: :tongue:
    RangerNeil wrote: Sun Sep 05, 2021 11:00 am Looks an interesting build.... I wouldn't mind adding this to the stash when normality returns. Will be following this with interest!! :)
    Comes in 1/35 and 1/24
    ForbesHutton
    Post by ForbesHutton »
    I did the Revel version years ago (same kit, someone re-boxed someone else's).
    It's a frustrating kit, but doable.
    https://hosting.photobucket.com/albums/ ... 7a3b3c.jpg
    https://hosting.photobucket.com/albums/ ... b6be0b.jpg
    https://hosting.photobucket.com/albums/ ... 08b70c.jpg
    Leave the seats out until all the interior painting is done and remember that on this one you can't hide mistakes under a camo net.
    digger303 wrote: Sun Sep 05, 2021 12:38 pm
    Does it come mit der Fuhrer - or any figures at all? I like the sound of 1/24th - my aged fingers might cope with that.... :) :(
      RangerNeil wrote: Sun Sep 05, 2021 7:27 pm
      3 male and one female figure, but not the top dog.Reasonably well molded for the times too which is a nice addition.
      edit.... I don't think the 1/24 has figures.
      ForbesHutton wrote: Sun Sep 05, 2021 4:42 pm I did the Revel version years ago (same kit, someone re-boxed someone else's).
      I knew I was justified in avoiding this kit all these years :lol:
      I hope I can do mine as good as yours. I love that interior color you used it is strikingly good .
      Ps....thanks for the interior tip
      ForbesHutton
      digger303 wrote: Mon Sep 06, 2021 1:09 am
      It would be a Tamiya, it's been 10 years, but looking at the collection XF-79 (linoleum deck brown) is the one I'd say I used.
      WordenB
      Post by WordenB »
      Watching this one with interest, I keep looking at the 1/24 version but assume construction would be similar.
      I'm struggling a little with the small size of the instructions and some parts are mis numbered. However the rear suspension is complicated with tiny bits and as normal I stuffed it up and had to pull it apart and redo. It still isn't right but not too bad I hope. There is about 2 hours work in that area for a competent builder.
      I also assembled some of the body work. The rear trunk doesn't fit snugly to the body work and need a bit of filing , carving and then filler to get a acceptable fit.
      The engine is nicely done and there are a lot of great details all over the kit. The chassis rails are separate pieces which I believe I am at fault in introducing a twist into and the front wheel will be off the ground, but it's too hard to pull apart and try to fix and I might not be successful in any case. If I was doing it again I would turn it upside down and tape it down to the table and just glue the front cross member. The assemble some of the suspension parts at the rear to the chassis rails and the cross support then leave it for a few hrs.
      Some might notice I just broke the fan blades off too... :doh:
      :th: :cheers2:
      Nice progress Digger ! Never thought this "phobia" would give you that much trouble. Lovely details and really small parts ! It's nice start !
      Garion77 wrote: Tue Sep 21, 2021 12:02 am Nice progress Digger ! Never thought this "phobia" would give you that much trouble. Lovely details and really small parts ! It's nice start !
      It's my way I think to make trouble for myself :lol:
      I'm hoping I maybe able to take some of the twist out when I add the body to the chassis and then possibly because the wheels are a loose fit finagle a better result.
      WordenB
      Post by WordenB »
      Coming on very nicely, it does look well detailed and right up my street, I can feel the 1/24 version getting closer!
      WordenB wrote: Sun Sep 26, 2021 5:19 pm Coming on very nicely, it does look well detailed and right up my street, I can feel the 1/24 version getting closer!
      :th: :th:
      ForbesHutton
      digger303 wrote: Mon Sep 20, 2021 3:38 pm I'm struggling a little with the small size of the instructions and some parts are mis numbered. However the rear suspension is complicated with tiny bits and as normal I stuffed it up and had to pull it apart and redo. It still isn't right but not too bad I hope. There is about 2 hours work in that area for a competent builder.
      :th: :cheers2:
      I hate having to assemble the basic frame/chassis when it's easy enough to mold. If you're the same stick with Dragon half-tracks, the Trumpeter half-tracks are all multi-piece frames.
      You could try warming it in hot water and twisting it back to a proper shape, but it could also go pear-shaped quickly.
      ForbesHutton wrote: Mon Sep 27, 2021 5:40 am
      :th: :cheers2:
      Thanks Forbes, but It has so many cross members The hot water trick might be like you said. Pear shape as soon as ones increases the pressure as it resists.
      I actually only have one Trumpeter half track the others are mostly AFV. Doesn't dragon have a issue with the drive wheel being too small in diameter and floating above the ground ?
      :th: :th:
      digger303 wrote: Mon Sep 27, 2021 11:12 am
      :th: :cheers2:
      :th: :th:
      You could try your original thought and tape or clamp the assembly to a solid surface and then gently pour very hot - NOT boiling - water over the area(s) where the twist is for a few minutes then allow it to cool. That minimises the pear-shaped risk??
        I've decided to press on.
        But I've got to show you what I think is a clever design.
        What a great way to add the door hinges. The small piece goes into a slot on the inside of the door to give good detail on such a small part. Love it.
        I hate these instructions.....So small and very hard to note exactly where some parts locate correctly. It's made me go extra slow and then still get it wrong.
        A quick mock up that doesn't sit flat for some reason. It will once I clamp it down.
        and one of the under side. The keen eyed will also notice the windscreen frame is bent in 2 places. That is as it arrived here many moons ago and is apparently a common occurrence. The plastic is flexible to a small degree and then it just snaps. I've broken 4 parts one twice of the very fine parts.
        A note for anyone building this kit don't follow the instructions and install the fuel tank when they say. Do it after the chassis and seating area are joined.Also install steering column to the instrument panel early and not to the chassis as they would have you do.
        Thanks for taking a interest guys presuming there aren't any gals here
        I've been putting all the real fiddly bits and pieces like door handles and such. Of course as I've been doing that I managed to break several pieces on the opposite side of the car when working on it. I decided to replace some of those parts with brass rod as the plastic is so brittle one only has to breath on the finer parts and they snap. Still deciding whether I should fabricate a new steering arm or just leave it off. Other than that 'm about ready to throw some primer on.
        Oh and I broke a window too through being hamfisted :doh: and in a hurry.....That has bugged me the most ....lately ;)
        true it's look fiddly... the steering wheel mostly ! don't give up ! it still looking good ! How do you plan to repair or replace the window ?
        Cheers buddy !
        Garion77 wrote: Tue Oct 05, 2021 12:07 am true it's look fiddly... the steering wheel mostly ! don't give up ! it still looking good ! How do you plan to repair or replace the window ?
        Cheers buddy !
        The windows have molded in frames. If I tried to fabricate a new window I fear it would stand out just as much. My second though was have the window half down as the crack only goes half way up, but I dismissed that for the same reasons. I tried using watch makers cement, but again not successful. My last thought was to re polish dip it in AK Gauzy install it and use the tried and true method to disguise it. I first thought I could get some clothing and drape over it, but my spares cupboard didn't have any clothing that was drape able. So unless I throw a flag over it I'm at a cross roads.
        digger303 wrote: Tue Oct 05, 2021 12:57 am
        Cheers buddy !
        Don't know if it would work but may be melt clear sprue and mold the window and then dip it Gauzy after a good polish
        Sorry it's being fiddly but it's looking good overall!
        You can make a window a few ways
        1. Thin styrene frame, clear thin acrylic sheet…various sources possible I have some from safety glasses I cut out
        2. White glue thinned a bit used inside the broken area and frame to span the crack. Drag the glue across and let it set. Repeat if needed for thickness.
        3. Gauzy agent. Dip frame into gauzy and let it set up inside the frame. Repeat for more thickness
        Problem is you may have to make the other windows as well to make everything match
        Definitely make new steering wheel arms. Telescoping brass rod thickness of appropriate diameters give and arm and a knob handle. You can pin it into the steering column with thin brass too and CA glue it. This will be lightyears better than brittle styrene
        Take a photo of the instruction section and blow it up on your phone or print it out larger on your pc printer
        I like my cars in no smaller than 1/24 scale
        This is starting to look pretty darn cool
        MrBowcat
        Post by MrBowcat »
        Shame about the broken window, but the build is looking great so far.
        Si vis pacem, para bellum
        Just caught up with this and it all looks nicely detailed, although it's a real shame about the window splitting on you :(
        As for getting all four wheels level this is something I seem to hit with a frame chassis every time. It doesn't seem to matter how careful I am during the construction, keeping everything flat and testing as we go along as soon as I do the final fit of the wheels it's bloody wonky!
        Tomcat64 wrote: Fri Oct 08, 2021 2:14 pm Just caught up with this and it all looks nicely detailed, although it's a real shame about the window splitting on you :(
        If I have to do another chassis like this I may build a clamp to hold it all down flat while the cross members are cemented in.
        Same here - I spent ages making sure the stub axles on the BTR-60 all lined up - and when I test fit the wheels the L/H rearmost sits high..... Grrrr.... :evil:
        There MUST be a better way of getting things aligned but so far its eluding me....
          I haven't parked this on the shelf yet.....work continues slowly.
          WordenB
          Post by WordenB »
          Looking very good, glad to see you are continuing on despite the issues. I ended up buying the 1/24 version but not started yet.
          WordenB wrote: Fri Dec 24, 2021 2:37 pm Looking very good, glad to see you are continuing on despite the issues. I ended up buying the 1/24 version but not started yet.
          thanks believe it or not I have the 1.24th too. Thought I would build it if there was ever a car build on the forum.
          Very late to this one :doh: looking good Digger :th: :pop:
          Kevthemodeller wrote: Thu Jan 06, 2022 9:02 am Very late to this one :doh: looking good Digger :th: :pop:
          Thank you....I'm pretty late to it too.... :lol:
          My clumsiness knows no bounds, if you have been following the Pfalz build you know of my complete cock ups lately. Seems to have started when I knocked my engine off the bench. It was stuck in a piece of foam and it also had the steering wheel for my G4 in it. Totally forgot about it when I rescued the engine and didn't find it until today when on bended knee and a torch and was looking for something else.
          It barely stayed in one piece all the centre is busted up.
          I have since taped the edges to bench and with tweezers straightened it out and added 7 dabs of cement to the 7 breaks. A repaint and it will be almost like new.
          Well... nothing like setting yourself extra challenges on a build I guess :lol:
          Tomcat64 wrote: Fri Jan 07, 2022 1:58 pm Well... nothing like setting yourself extra challenges on a build I guess :lol:
          :oops: :( :lol: :lol: :lol:
          Tiny weeny update......PE can be a pain , but masking up this is a pain.
          .4 and .7mm tape.
          digger303 wrote: Mon Jan 10, 2022 1:40 pm Tiny weeny update......PE can be a pain , but masking up this is a pain.
          .4 and .7mm tape.
          Ooh - now that's some fiddly masking - nice neat work though mate :th:
          that is a tough job !! patience required !! I don't know if you've used Aizu tape... but what I don't like about them is that they don't stick enough to my taste. So now, when I don't have a lot to do, I prefer cutting Tamiya's tape with my Infini cutting mat.
          Nice job !
          Wow! That's some dedicated modeling!
          Oops don't you just hate it went you break something :pistols: I'm sure you'll get it sorted Digger.
          Loving the masking :banana: :th: :pop:
          Garion77 wrote: Mon Jan 10, 2022 11:27 pm that is a tough job !! patience required !! I don't know if you've used Aizu tape... but what I don't like about them is that they don't stick enough to my taste. So now, when I don't have a lot to do, I prefer cutting Tamiya's tape with my Infini cutting mat.
          Nice job !
          Your on the money....Aizy tape.....and yes it isn't as tacky and also the glue is a little jelly like. I can actually push the tape around .
          I may indeed do as you do, but I'll see how it goes and try to use up what I have. I hope it doesn't go pear shaped.
          Kevthemodeller wrote: Wed Jan 12, 2022 11:59 am Oops don't you just hate it went you break something :pistols: I'm sure you'll get it sorted Digger.
          Thanks....took some fin dangling and cursing to get it to line back up.
          BigWall wrote: Mon Jan 10, 2022 11:37 pm Wow! That's some dedicated modeling!
          Thanks....can't wait to get back to some armor.
          cheers guys
          Getting near the end, but it seems like one step forward and 2 back. I have to go back over and try to touch up some areas with a brush and For me it always shows what was hand painted and what was airbrushed. Took me a age to work out what grey I used originally :( .
          Never mind progress is being made, but this has to be my worst paint job ever.
          Looks alright from here.
          Looks good in the photo Digger!!
            For me it's a good paint job ! Don't forget, we're always our biggest critic ! From what we see in the picture it's great !
            May be it's all the bumps you've encountered in this build that makes you harder on yourself. Keep it up my friend !
            ForbesHutton
            digger303 wrote: Fri Jan 28, 2022 1:23 pm Getting near the end, but it seems like one step forward and 2 back. I have to go back over and try to touch up some areas with a brush and For me it always shows what was hand painted and what was airbrushed. Took me a age to work out what grey I used originally :( .
            I had the same experience with mine, a pain to build and a nightmare to paint.
            Just keep fighting the urge to chuck it at a wall and realize this is one that will NOT be "perfect", take smaller steps towards "good enough".
            ForbesHutton wrote: Fri Jan 28, 2022 7:29 pm
            Kind words Forbes, but this just kept getting worse and I was sorely tempted to chuck it.
            Lost the side window when removing the masking tape. Loads of shaky paint work and many other faults , but honestly life is too short so this is as good as it's going to get. Bit embarrassing even posting it, but heck I'm in this to the bitter end.... :lol:
