For some time I have been after some small friction clamps like these from ModelsRGo.
Unfortunately this company seem to have closed down some time ago and the clamps are like the proverbial hens teeth. I wanted some as they would be useful on occasion when you want to hold something together but not exert spring clamp pressure, for example when holding an aircraft fuselage together for gluing. The advantage of these clamps is that with only friction holding the jaws together they can be adjusted to just light finger pressure.
Every now and then I have a look online to see if any have become available or if anyone else has started making them, but to date no joy. So I decided to make one to see how difficult it would be. Turns out, not that difficult at all. This one is only a prototype with materials I had to hand, I will test it out and if it works OK will make some more, possible using aluminium for the jaws.
No doubt for anyone with a 3D printer this would be a simple job, it took me a couple of hours in my workshop with a pillar drill, a bandsaw and a lathe.
