Academy 1/72 Hawker Hurricane II - W.I.P.
Daishi12
Post by Daishi12 »
Just a quick post for a work in progress, the Academy 1/72 Hawker Hurricane IIb.
Very well detailed kit that went together very nicely. No major filling or sanding to be done at all. The only criticism that I would have is the fact that the instruction sheet does not specify which paints are required, (hat off to Lee as he was able to work out they where Mr Hobby :bow:: ) and also that the decals are not the best quality in the world.. they are very thin and quite fragile and the roundalls where a bit out of alignment. I would say all in all a nice little kit that I enjoyed putting together.
Paint is Tamiya spray primer, the lower surfaces airbrushed black (combination Tamiya rubber black and Revell black) the upper surfaces are hairy stick painted Revell Dark Green and mid grey.
As always any comments or criticisms welcomed.
Just one last note, canopy was freehand painted without masking and has not been touched up.
W.I.P.
Revell 1/72 P-47M
Re: Academy 1/72 Hawker Hurricane II - W.I.P.
Nice work daishi. I've built this kit and its a nice kit. You did a great job too :thumb2:
looks good mate love the hurricane going to have to get another in 1:48 soon me thinks
Bridon
Post by Bridon »
Nice job...always liked the Hurri...for freehand, that canopy has turned out very well :thumb2:
EasyEight96
Malaysia
Post by EasyEight96 »
Nicely done there mate would recommend to touch up the camo other than that it looks very beautiful
In -progress
Too many on the bench!!!
Matchbox Kits lover....
Daishi12
Post by Daishi12 »
I'm really impressed with the quality of the Academy clear parts, very thin and in scale for 1/72 (unlike Airfix for example) and the framing lines are excellent.
W.I.P.
Revell 1/72 P-47M
Post by Rob »
Nice one! A well wielded hairy stick too
HWGuderian23
Post by HWGuderian23 »
Nice work Daishi :th:!
Thanks for sharing mate :cheers2:!
Daishi12
Post by Daishi12 »
HWGuderian23 wrote:Nice work Daishi :th:!
Cheers mate, the Hurri is on hold at the moment while I'm working on the Holy Toledo and Cold War GB...will be coming back to this one to weather and lacquer.
W.I.P.
Revell 1/72 P-47M
HWGuderian23
Daishi12 wrote:Cheers mate, the Hurri is on hold at the moment while I'm working on the Holy Toledo and Cold War GB...will be coming back to this one to weather and lacquer.
That's nice to hear mate :th:!
So let me come back later on to check it out again!
P.S.: Good luck with your GB's :cheers2:!
