MV-22 Osprey | Hobby Boss | 1:48
Parker
Post by Parker »
Thought I'd give this a go.
An aircraft with a somewhat checkered history.
Cheers all.
P
Re: MV-22 Osprey | Hobby Boss | 1:48
I have the Italeri version with some extras so I'll be following your for inspiration (smile)
It did indeed have a rough start when initially deployed but much like the Harrier. But after the bugs were addressed and the correct operating envelopes identified and trained, they both have had a long and distinguished term of service. Have you figured out what camouflage scheme your going to apply (current gray, middle east, or early green)?
The JGSDF has an interesting color set and Pentrest has just about anything you can imagine, including a digital desert camouflage used by the Navy Seals.
krusty69
Post by krusty69 »
:pop: have that kit sitting on the shelve with all the goodies, trying to hang on until the helo build later this year, and hope they let a tilt rotor in. :th: i'll be watching with interest
Major General
Major General
Gonna be a big S.O.B :pop:
smokeriderdon
Post by smokeriderdon »
DRUMS01 wrote: Fri Jul 07, 2023 1:27 am I have the Italeri version with some extras so I'll be following your for inspiration (smile)
Actually it is still plagued with issues. The USAF grounded their entire fleet due to power transfer issues. That was in 22. Not sure if they still are or not.
Parker
Post by Parker »
DRUMS01 wrote: Fri Jul 07, 2023 1:27 am Have you figured out what camouflage scheme your going to apply (current gray, middle east, or early green)?
Haven’t decided yet, but the digital camo sounds interesting!
krusty69 wrote: Fri Jul 07, 2023 4:14 am :pop: have that kit sitting on the shelve with all the goodies, trying to hang on until the helo build later this year, and hope they let a tilt rotor in. :th: i'll be watching with interest
I’ll vote for the helo build! Perhaps Tilt Rotor could be a build category?
Stokesy44 wrote: Fri Jul 07, 2023 7:51 am Gonna be a big S.O.B :pop:
Yes indeed. Might have to display all folded up!
smokeriderdon wrote: Fri Jul 07, 2023 5:03 pm Actually it is still plagued with issues. The USAF grounded their entire fleet due to power transfer issues. That was in 22. Not sure if they still are or not.
Reading about the V22's issues has been interesting.
Such a tremendous amount of money thrown at it.
Parker
Post by Parker »
OK, made a start.
First up is the cockpit. A few tiny fiddly bits to assemble and attach to the instrument/display panel, not entirely sure if I did them correctly, but it all gets painted black so on the grand scheme of things not that critical.
Onwards, upwards, sideways and occasionally crashing.
P.
martindavid
Post by martindavid »
Looks like a fun build, nice start
Looking forward to seeing this go together - I built the Hasegawa 1/72 version a few years back :pop:
Parker
Post by Parker »
I have totally underestimated how big this is.
Parker
Post by Parker »
Righto. Managed to get a fair bit done in the past few days.
Started all the panting of the propellers on the sprew, then noticed the little fire extinguishers.
Cockpit came together quite well, roughed it up a bit.
Then the often thought “no one is ever going to see this but I know its there” process.
Parker
Post by Parker »
Contemplated having the rear doors able to open, then dismissed that thought.
It was about this stage that it dawned on me how big this bird is.
The side elements plus the rear wing really give the bird some length & girth.
Parker
Post by Parker »
There’s going to be a bit of plastic putty required on the seams both top and bottom.
When the outer shell/fuselage was attached there's a couple of points the dont quite marry up. I'm putting the down to user error.
Parker
Post by Parker »
for comparison...
here's my recently completed FA18 beside it.Image
Parker
Post by Parker »
So, now to the wing!
Parker
Post by Parker »
Tonight, its on to the propellers!
Cheers all.
P
Lookin good so far! Are planning on adding crew members will this bird be on the ground?
Once you responded with the history of the mishaps I checked deeper and this is a little of a problem child. I also read where Japan was protesting the deployment of the Osprey to Japan bases because of the safety record. Even though it offers capabilities that no other aircraft can offer, it has had parts quality and design issues, let alone a flight envelope that was not properly addressed when first deployed.
Keep up the great work.
Parker
Post by Parker »
DRUMS01 wrote: Mon Jul 17, 2023 7:35 pm Lookin good so far! Are planning on adding crew members will this bird be on the ground?
This bird will most certainly be grounded.
Parker
Post by Parker »
these propellers are massive!
Parker
Post by Parker »
quite an amusing podcast on the V22...
Parker
Post by Parker »
nearly ready for paint.
needed to fill a few gaps.
Cheers all.
P
Certainly a bit gappy, but your plugging them good.
Keep up the good work.
Parker
Post by Parker »
digger303 wrote: Fri Jul 21, 2023 7:25 am Certainly a bit gappy, but your plugging them good.
Cheers Digger.
Pretty sure the gaps are my fault. The outer fuselage wrapped around the inner fuselage caused a few mis alignments.
I’m watching with interest if krusty has/will encounter the same thing.
ForeverPlasticKits
Post by ForeverPlasticKits »
One week of building and the result is really good, even if there is some holes to fill. :thumb1: :thumb2:
Parker
Post by Parker »
Masking and painting.
Cheers all.
P
Major General
Major General
Its coming along :th:
Wow look at you go!
Just ripping along with the build :th:
krusty69
Post by krusty69 »
Parker wrote: Fri Jul 21, 2023 8:58 am
Cheers Digger.
Been wondering the same thing :th:
Parker
Post by Parker »
Bit of a painting issue.
Not with the actual paint or painting, but the colour.
The instructions are incorrect for one colour, and tbh, I’m questioning whether they’re also wrong on another colour.
I’m using Tamiya and the instructions call up XF58 as a medium grey, in reality, XF58 is Olive Green.
Additionally, the instructions have called up XF20 for the main upper fuselage, wing and tail, which, looking at the colour of the paint guide should be a slightly darker (slightly blue) grey than XF19 used for the underside (and smaller side section of the fuselage).
When applied, XF20 looks green/grey. Quite annoying.
So, now in a quandary of what to use.
Leaning toward XF83.
Going the other way and looking at the Mr hobby recommendations....H305 is medium grey......xf58
H306 is light grey..........xf20
H308 is very light grey.....xf19
Very different from your spoons and I always go with the first colours they list in those charts cause I figure thats the colour they are going for and every brand listed after that is their closest equivalent and is mostly not a close match.
Well that's my take any way not sure if it's helped or confused.
Parker
Post by Parker »
First coat.
Hopefully only 1 more required.
Parker
Post by Parker »
Final coat completed.
Official drying area.
Tiny decals and propeller.
Very proud of myself that I managed to paint on the tiny red light using a toothpick, only to then realise that I’d painted it on the wrong engine.
Onwards, upwards, etc...
Cheers all.
- P
Ha ha
It's slowly coming to life and looking all right.
Mind you I think you might have been tempting fate with the cat.
ForeverPlasticKits
Nice progress on this big heli-plane! :thumb1: :thumb2:
Parker
Post by Parker »
Managed to get a few decals applied last night.Image
Need to make a visit to the hobby shop. The big bird needs a lot of clear coat!
Parker
Post by Parker »
The propellers are windmills!
Nice.
Could be dangerous just going to the LHS for paint :thumb1:
Major General
Major General
That's looking very good. Decals have gone down well and the paint is :th:
That's come together really well - great work on sorting out those seams, and as the guys already said the paint looks spot on :th:
Parker
Post by Parker »
Weathering has commenced.
Dirty bird incoming.
Parker
Post by Parker »
DONE
AWESOME POSE !
:clap: :clap: :clap:
