1/35 ICM CH-54A Tarhe
smokeriderdon
Re: 1/35 ICM CH-54A Tarhe
Post by smokeriderdon »
I have this in the stash. How did you like it?
And looks good!
Looks good
Thats a really nice build - congratulations!!
:cheers2: :cheers2:
    Hobby Boss 1/350 Surcouf
    Mikro Mir 1/350 HMS M1
    stoves
    Post by stoves »
    smokeriderdon wrote: Fri Sep 22, 2023 6:29 am I have this in the stash. How did you like it?
    And looks good!
    Thank you. It was good for the most part. The front windscreen required some sanding to fit right. Not a fan of ICM's decals. Very fragile.
    A Gringo in Mexico
    On the bench: Takom 1/16 Jeep
    Very well done!
    stoves
    Post by stoves »
    Thank you.
    A Gringo in Mexico
    Nice work. I've always liked this helicopter
    stoves
    Post by stoves »
    Thank you.
    A Gringo in Mexico
    Very nice stoves... this is my next build. you did very well on and around the glass both front and rear.
    Was your build straight out of the box?
    If not what extras did you add?
    Was there any issues with fitment of the body panels over the internal skeleton?
    Other than the cockpit glass is there anything else I need to look out for?
    And thanks for the insight on the decals as I've never used them before either. Looking at the rotor span over the table, that has to be huge!
    Ben
    stoves
    Post by stoves »
    DRUMS01 wrote: Sun Sep 24, 2023 8:52 pm Very nice stoves... this is my next build. you did very well on and around the glass both front and rear.
    Ben
    Thank you. It's straight out of the box. The only aftermarket I used was Eduard's masking set. Yeah the front windscreen requires some sanding to fit right. I watched a build series on youtube. They showed how they fixed the fit of the front windscreen. I did the same thing. The fuselage panels fit pretty good. The rotor diameter is two feet.
    A Gringo in Mexico
