Paul’s Eduard 1/72 MiG-15
Quax
Greenland
Post by Quax »
Just a photo of the box for the moment…
More to follow
A mess as usual...
Re: Paul’s Eduard 1/72 MiG-15
:th: :th:
:pop: looking forward to seeing this one come together mate!
Major General
Major General
Looks like a nice kit. looking forward to seeing this getting built up
Quax
Greenland
Post by Quax »
contents of box as promised
This is the North Korean scheme that's part of the kit and will be the one I do.
cheers
A mess as usual...
The detail on that styrene looks aweseome :th:
Nice looking kit, with PE to boot.
Quax
Greenland
Post by Quax »
Hi all and thanks for looking...
this is the story so far, it actually goes together reasonably well, there are some microscopic levers in the PE set that I have omitted mostly because I couldn't see them... :crazy:
I cut off most of the primary internal bits for spraying, I used AK 3rd Gen Black primer and then as it seems the Korean MiGs were grey in the cockpit I used AK RAF Ocean Grey (RC288) mostly because it was close enough and I already had it! the silvery bits are AK Extreme Metal Matte Aluminium (or Aluminum if you prefer... :shifty: )
After which it was add the PE bits which all went on ok and look the part
The cockpit walls are added to the central frame which also has the nose wheel housing included. in the top is where the added weight has to go and there is a section underneath, unfortunately it doesn't say how much on the sheet so its as much as I could get in there.
there are no locating pins for the fuselage, its the cockpit and the jet nacelle that help you but it did require some pushing and pulling as well as clamps and tape. I found it easiest to start at the tail and work forwards.
after that the wings and tail go on, it all needed a little filler here and there and the under nose section was not a great fit for me although it looks ok. I added the underwing attachments for the drop tanks, the instructions didn't make it clear which tanks were for which version so I picked the ones I liked :shock:
The undercarriage legs have also been added
I decided to do the canopy open so have taped up the seat and then covered with white tack and shoved a stick up its ....jetpipe for handling purposes :o
the MiG was then primed again with AK Black as well as the drop tanks, canopy and a couple of aerials
more in next weeks exciting episode of.... that geezer from down the road Barton, Special Agent.....! :pistols:
cheers
A mess as usual...
Nice work in the cockpit.
:clap: :clap: :clap:
Major General
Major General
Nice work on the cockpit and the kit looks sexy in the black primer :crazy:
Quax
Greenland
Post by Quax »
thanks guys
so for the top coat because I don't have any of the official colours I used the following as best endeavours:
MRP Olive Green RAL6003
MRP RLM65 HellBlau
AK No6 Earth Yellow (RC030)
Tamiya XF79 Linoleum Deck Brown
Alclad Gloss and Matt
Brown Modellers Oilwash for the panel lines
The decals were a bit plasticy and didn't really want to settle in panel lines even with assaulting with Ultimate heavy stuff :scratch:: but no silvering and very little carriage so the look good. Interestingly there are stencils in the decal set but only for 2 of the 5 versions and mine wasn't one of them :banana: :banana: The top wing stars are also not added (and the box art is the same) but they are on the decal sheet if you wish.
As a kit it went together ok for a ham fist like me ad the undercarriage had good slots which helps!! A couple more photos in the reveal section.
cheers all
A mess as usual...
Major General
Major General
Very good camo job :th:
Love those camo colours.
Nice job ! the camp looks wonderful.
MRP paint are hard to get for me, even almost impossible. But the few bottles I have are to me the best paint.
You did a great job with the different demarcations !
Oh yes cracking cammo there Paul :banana: :pop:
Tamiya FORD GT
