I added the Quinta studios 3D decals for the cockpit
details removed for the decals and then primed with Mr Surfacer1500
cockpit detailed and assembled
cheers
What he said.
You could be right, product substitution perhaps.Kevthemodeller wrote: ↑Sat Feb 21, 2026 5:50 pm Paul superb primer and paint lay down![]()
I've had similar further issues with some decals on my current GT build, nothing to post about as I managed to work around it. Basically they all seem so dam brittle, in that having to cut them where they cross bonnet and rear wing to body gaps, they just crumbled/cracked/disintegrated. Luckily these gaps are .25mm so can't really be seen, but I'm really beginning to wounder, if we're not seeing cost cutting which is leading to material degradation of time![]()
Good save though and you did exactly what I had to do on the FW190![]()
