transparent colours on a canopy
mattsmith
Post by mattsmith »
Could you wonderful people tell me the best way to paint the oval bit at the front of a canopy ( f14 and f4 phantom) with transparent colours.
It's not just canopy's I'm having trouble with its the top of helicopter glass work too (ie, a sea king has green glass above the seats)
I have tried and tried but it just looks crap. it pools around the edge and doesn't give a nice even looking coat to it.
Please please help!!!!!
Re: transparent colours on a canopy
Are you airbrushing or using a hairy stick?
mattsmith
Post by mattsmith »
was brushing.
but will do either if it works
I would say have a go with the airbrush and do it in very, very light misting coats and build it up slowly :th:
Daishi12
Post by Daishi12 »
I had the same problem with my OV-10a Bronco, so had an experiment with ink. I used Revell Contacta Clear on the inside of the fusalage and when that was still tacky brushed on a coat of Derwent Inktense sea blue.
W.I.P.
Revell 1/72 P-47M
Johni044
Post by Johni044 »
I use Humbrol clear colours and don't have many troubles but it does need mixing A LOT and white spirit dosen't cut the mustard when cleaning. Need to get the heavy guns out to clean the brushes ie cellulose thinners.
Oh and normally applied with a flat brush unless the shape of the part being painted makes this impractible.
My Portfolio
2014: acquired 51; Built 27
On the bench, Urm a lot.....
5Craven
Post by 5Craven »
If your airbrushing give Tamiya's transparent colours a go. Another tip, which I haven't tried, is to dilute your colour (acrylic) in Klear and then spray that.
mattsmith
Post by mattsmith »
cheers guys for the tips will give it a go...
Lego
Ireland
Post by Lego »
I have used tamiya clear paints mixed 50% thinner.
