So i took some military gauze bandage and a mixture of tea and marjoram, as you can see they are both grinded. Make sure the particles have the right size, it shouldn´t be too fine.
Then i mixed some water and wood glue together put the gauze bandage into it so its soaked with the glue.
Next i put the soaked bandages on the tank.
Finally i mixed the tea and marjoram with wood glue and water aswell and applied it on the netting.
When dried up its solid and can be painted the way you want to.
I´m amazed how easy it was, i plan to build a modern tank with a camouflage netting all over it, i think it will look awesome!
