Gluing Photo Etch
- MerseyTrainz
- Master Sergeant
Gluing Photo Etch
Hi ISM modellers,
What glue(s) do you use for adding/gluing your photo etch parts to your models, that is, other than super glue.
- Paul
- Site Admin
- Contact:
Re: Gluing Photo Etch
You can use pva glue, which gives you much longer time to position the parts,but it's not as strong a bond as ca glue
Products I use in my builds viewtopic.php?f=192&t=27234
My Paul-Ism page https://www.facebook.com/thebenchwithpaul/
Friday Live show here https://www.facebook.com/groups/120548821977514/
- MarkVerploeg
- Major
i use ca glue but the gel type this is much thicker but the parts can be moved longer then with regular ca glue
it is better to use with resin aswell for the same reason
but are you and Paul neighbors? just saw you are both from Wirral
- Paul
- Site Admin
- Contact:
Yeah we are literally about 5 mins away from each otherMarkVerploeg wrote:i use ca glue but the gel type this is much thicker but the parts can be moved longer then with regular ca glue
Schoof
- Chief Warrant Officer 3
Paul wrote:Yeah we are literally about 5 mins away from each otherMarkVerploeg wrote:i use ca glue but the gel type this is much thicker but the parts can be moved longer then with regular ca glue
Poor poor MerseyTrainz
Uhm. .... That. ..... And. .. uhm. ... That. ..... And. ..... uhm. ..... That. .... And. ... uhm. ..
waaaaaaaaaaaaay too much
Stonkmer
- Corporal
What about gluing PE onto clear parts (Canopies, etc)?
Will Ca not frost it up?
- Paul
- Site Admin
- Contact:
Like I said use pvaStonkmer wrote:What about gluing PE onto clear parts (Canopies, etc)?
- MarkVerploeg
- Major
i have seen "special" pe glue wich comes in a bottle.with a needle
but i'm not sure if that is any good
- Rob
- Chief Warrant Officer 2
Paul, is that just ordinary PVA/white glue you use?Paul wrote:Like I said use pvaStonkmer wrote:What about gluing PE onto clear parts (Canopies, etc)?
My Youtube Channel: http://m.youtube.com/user/MrBobsBuilds
- Paul
- Site Admin
- Contact:
It's microscale crystal klear, which is just a pva glue really, you could use normal pva tooRob wrote:Paul, is that just ordinary PVA/white glue you use?Paul wrote:Like I said use pvaStonkmer wrote:What about gluing PE onto clear parts (Canopies, etc)?
- Rob
It's microscale crystal klear, which is just a pva glue really, you could use normal pva too[/quote]
Thanks Paul. I have some of that so I'll give it a try
LocoFeldwebel
- Corporal
For tiny details, try using Future to bond to clear canopies.
Dragon 1/35 Panther A
CyberHobby 1/35 StuG III F.
On the shelf
Tamiya 1/35 Panzer II
On the shelf
- MerseyTrainz
- Master Sergeant
Thank you all, for your replies.
Newfieal01
- Private First Class
Thanks for posting this one. Just the information I was looking for
- hook1169
- Staff Sergeant
I have a hard time with extremely small pe parts. Been doing my first real pe work on a 1/72 morser Karl and I seem to "over" glue the parts. Where I get a glob or mound of ca that endsups covering the tiny part I am adhering and then will look bad when painted. Not sure how to put such tiny amounts of ca on pe. Or at least haven't figured it out yet.
- ForbesHutton
You can buy little kits for applying CA, consisting of a base of plate and an applicator. I just put a bit of cheap masking tape (not wasting expensive Tamiya tape) on the table and put a drop or two of CA on it. I then use toothpicks (cocktail sticks) to pick up glue from the tape and put it on the part(s). When done I pull up the tape and throw it and the pick/stick in the garbage so I don't risk putting something (or myself) into the remaining glue.hook1169 wrote:I have a hard time with extremely small pe parts. Been doing my first real pe work on a 1/72 morser Karl and I seem to "over" glue the parts. Where I get a glob or mound of ca that endsups covering the tiny part I am adhering and then will look bad when painted. Not sure how to put such tiny amounts of ca on pe. Or at least haven't figured it out yet.
- UKguyInUSA
- Second Lieutenant
- Location: New Hampshire, USA formerly Palm Beach, Florida, USA and Leicestershire, UK (until 1999)
- Contact:
ForbesHutton wrote:You can buy little kits for applying CA, consisting of a base of plate and an applicator. I just put a bit of cheap masking tape (not wasting expensive Tamiya tape) on the table and put a drop or two of CA on it. I then use toothpicks (cocktail sticks) to pick up glue from the tape and put it on the part(s). When done I pull up the tape and throw it and the pick/stick in the garbage so I don't risk putting something (or myself) into the remaining glue.hook1169 wrote:I have a hard time with extremely small pe parts. Been doing my first real pe work on a 1/72 morser Karl and I seem to "over" glue the parts. Where I get a glob or mound of ca that endsups covering the tiny part I am adhering and then will look bad when painted. Not sure how to put such tiny amounts of ca on pe. Or at least haven't figured it out yet.
Forbes employs the same method that I do....applying with cocktail sticks is accurate getting a small spot at the point you want it. You can even sharpen the end of the stick even more with a blade to reduce the surface area of contact for the glue to stick to.
- digger303
- General
steve zaloga uses kneadatite epoxy for small pe....more durable and not brittle. That is etch to plastic.
- Chip1942
- Corporal
I usually solder larger parts such as fenders it creates a much stronger bond than CA glues and is fine once you get the hang of it
http://wwwplasticmetal.blogspot.co.uk/
In Progress:
Hobby Boss T26 1938
Tiger 1 initial production turret number '121'
In Progress:
Hobby Boss T26 1938
- mixup1
- Private
Great advice guys, just what I was looking for. Just about to attempt to glue internal PE to the canopy of my Su-27 Flanker. Fingers crossed
- bluebottle
- Staff Sergeant
try Gator's grip... similar to pva but stronger....
WIP: Monogram 1/48 F-104C,Eduard 1/48 FAA Hellcat,Hasegawa1/48 RF-4E
- Vleugelmoer
- Sergeant Major of the Army
- Contact:
Hi there mersey trainz,
For the application of PE I use several different types of glue. I also use soldering it all depends on what and where I'm working on.
watered down PVA, used for large peaces that require some fiddling to get the correct placement.
straight PVA, used for scratch building modern canopy frames and small parts on clear parts.
quick type CA, used for the placement of small PE parts on non clear parts.
Soldering, used for stuff like small ammo boxes, structuralish parts like flaps speedbrakes and some gun barrels. I use this methode simply because of the strength of the bond. It also has a big advantage that it will react with burnishing and blackening agents so that they end result is just awesome.
Damm the glue is getting to me
Vrschoof
Hope i get this straight pva is just ur basic wood glue right? Otherwise correct me, i myself could use the awnser and im not to happy bout using super glue wich cures in 10 secs..
- MarkVerploeg
- Major
No it is not exactly the same
But close though
Pva is what we call white glue or knutsel lijm in Dutch
Allthough wood glue or carpenters glue contains a lot of the same substances it is stronger but turns yellow
Pva stays white or turns in to a milky white
Cristal clear from micro scale is a pva aswell but that turns in to a clear layer once it is dry
But close though
