Thanks, Here is the picture I promised last thread.
I did a dry fit and the top would not fit correctly. I figured out why this kit was shelved. The resin engine was not installed correctly. Easy solution just remove it. That was a pain in the butt. I broke about 4 other pieces off the side but finally got it out.
After everything was removed I was going to leave it out an then though you have all that resin use it. Lets make this a challenge. Plus if i screw it up I can always display it with the cover closed. Well i discovered that the instruction on resin really suck.
. I figure i needed to cut out some areas so that the resin would fit. Here is what I cut out.
I will cut this out tonight.
