Trumpeter 1/350 Udaloy 1
MichaelHoffman
Post by MichaelHoffman »
As I look upon the many fine builds, I noticed that most models are of Armour or Aircraft. With the exception of Roland's Zvezda 1/350 Battleship "Knyaz Suvorov", I noticed that Russian naval wessels are lacking in representation. So.. without further adieu, here is my submittal into my first group build of any kind.
Here is a Photobucket album of the kit. http://s641.photobucket.com/user/Gothmog1960/slideshow/
Details:
The Udaloy I class are a series of anti-submarine destroyers built for the Soviet Navy, eight of which are currently in service with the Russian Navy. The Russian designation is Project 1155 Fregat (Frigate bird). Twelve ships were built between 1980 and 1991, while a thirteenth ship built to a modified design as the Udaloy II class followed in 1999. They complement the Sovremennyy-class destroyer in anti-aircraft warfare and anti-surface warfare operations. The Project 1155 dates to the 1970s when it was concluded that it was too costly to build large-displacement, multi-role combatants. The concept of a specialized surface ship was developed by Soviet designers. Two different types of warships were laid down which were designed by the Severnoye Design Bureau: Project 956 destroyer and Project 1155 large anti-submarine ship. The Udaloy class are generally considered the Soviet equivalent of the American Spruance-class destroyers. There are variations in SAM and air search radar among units of the class. Based on the Krivak class, the emphasis on anti-submarine warfare (ASW) left these ships with limited anti-surface and anti-air capabilities.
This is a very nice kit, it is molded in grey, red and clear parts. The molding is crisp with very little to no flash. I found it unusual that the red hull parts are translucent, I do not know if this is normal for Trumpeter kits. The kit includes clear parts for both helecopters, and a sprue of clear windows. The kit does supply a fret of photo etch, but I decided to buy the Trumpeter photo etch for this kit. I have decided to push myself to the limit on this build. I will be trying new techniques, and methods of construction and weathering. With all the clear parts this kit is begging to be lit. I decided that I would do a diorama of the Udaloy punching through the waves at night, with cabin and bridge lights. I will not be using the helo's or underwater parts, as this one will be elevated and maneuvering through a major swell.
MichaelHoffman
Re: Trumpeter 1/350 Udaloy 1
Construction has begun. Since this is going to be lit, I have drilled the hull, 60 port holes not that bad. I have not decided if i'm going to go with ambient or fiber optics for these lights.
MichaelHoffman
Well after working 80 - 90 hours a week for the last month, I finally get to sit down and work on the Udaloy. Doors, Doors, and more Doors.
This tool was very useful, and saved a lot of blood.
Next, time to pull out the A/B and spray some paint.
Homerlovesbeer
Post by Homerlovesbeer »
wow this is a cool build! Photo etch overload :crazy: Keep the updates coming ;)
rwsmith14
Post by rwsmith14 »
Cool Subject, The Udalo is a great destroyer.. and anti submarine platform
MichaelHoffman
OK, well here is a major update. As my plan is to still light this thing, I am currently figuring out how many LED's and where to put them. And as such, masking off the windows is a must.
MichaelHoffman
I did find one issue with the kit. I was missing an area on the bridge floor (red circle), I had to fill it in with some plastic.
I had a fun time painting this kit.
MichaelHoffman
Starting to go together nicely.
MichaelHoffman
The bow/hull is in three pieces, it looked a little rough at first, but with a little help from some great products, it smoothed out nice.
MichaelHoffman
This white line was a lot easier than I thought.
MichaelHoffman
It looks Russian now, just placed for the moment. Need to place the SMD's and wire the hull. Need to source out the base and water effect.
MichaelHoffman
Ok, it is crunch time.....most of the assembly of the plastic is done. All that left is lighting, some touch up paint, the rest of the PE, and the base. Ok, now for the update.
I think I have the deck orange/red in the right shade, it looks closer in real light.
Ok, this is not a Borg Cube....priming the photo etch with Ultimate/Badger primer.
The primer lays down very nicely.
MichaelHoffman
The "Barley Gary" color. ?? Looks like a lighter version of ghost grey with a touch of green in it.
The last PE to be attached, the railings.
That moment when you know you are getting somewhere...the first empty sprue.
MichaelHoffman
Some of the tools of the trade....
1/350 scale chain...6 bucks per foot with 8 bucks shipping, oh the pain.
Aft superstructure is all fleshed out.
MichaelHoffman
Bow is looking good, it will pop once I get the washes and powders on it.
One of few times I wish it WAS photo etch, these were each 4 pieces and fiddly, spent almost an hour to get them together, folding would have been better and faster. If I had time I'd remake them in brass wire.
Looking berry Russian now.
rwsmith14
Post by rwsmith14 »
Nice !! Always liked the lines of the Udaloy. It was a great destroyer and anti-submarine platform.
rwsmith14
Post by rwsmith14 »
What color did you use for the deck?
MichaelHoffman
rwsmith14 wrote:What color did you use for the deck?
I used Tamiya XF-64 Red Brown. And had to mix my own for the Orange/Red from various brands.
MichaelHoffman
Well, while waiting to get a few parts for the lighting I put 85% of it together and did a waterline photo shoot just to see how he looks.
MichaelHoffman
Ok, 1 week to go... and it is getting close...I have built the lighting harness and tested it. and got the foam cut for the base.
MichaelHoffman
Placing the foam as required.
and a quick check on the ship placement
MichaelHoffman
Udaloy is looking good, here it has the gloss coat for decals and washes
MichaelHoffman
Pink foam board, placing the high spots and glued down, then craved with a dremel.
MichaelHoffman
Pianting the poam with med blue craft paint, and doing bioluminescence with a blue green paint.
MichaelHoffman
Adding the white to the caps and wake, quick dry brush, it a very windy night.
More tomorrow, adding the rest of the PE to the ship and placing it in it's slot. Then adding clear silicone to the surface to create the water, then white dry brush again.
MichaelHoffman
All the PE is on it. Final dull coat. Still have to pull all the tape from the windows, spread the silicone, and form it, and highlight. Almost done.
MichaelHoffman
The Udaloy 1 is done. Placed in it's water effect. And lit up.
MichaelHoffman
It turned out pretty good, need to work on my weathering. But not bad for a first time water effect, and LED lighting for a ship. Best of all I had a blast, the Trumpeter kit is a very nice, and with the Trumpeter PE set it was a nice easy build. It did have it issues, but nothing that could not be handled with a little pre-thought.
Always48
Post by Always48 »
awesome water effect and great explanation on how you achieved it. Am i right in saying you have used ordinary clear silicon sealent to create the clear depth to surface?
MichaelHoffman
Always48 wrote:awesome water effect and great explanation on how you achieved it. Am i right in saying you have used ordinary clear silicon sealent to create the clear depth to surface?
Yes, just squirt it, spread it, form it. ten use white to highlight the whitecaps on the waves.
Always48
Post by Always48 »
I am so going to have to try it, thanks what a great idea. :th:
JudgeDredd
Post by JudgeDredd »
That is amazing and your water looks fantastic.
I AM the Law
