Panther II by Dragon 1/35
hansolo
Post by hansolo »
Hi guys,
My entry will be the Panther II by Dragon.
I chose this model because it's a badass tank and I love the new gun with the round gun mantlet on it! :pistols:
Here's some history and some nice pics.
The Panther II tank was a German tank design proposal, based on the Panther tank during the Second World War. It had thicker armour when compared with the Panther and some standardised components were implemented from the Tiger II tank. The Panther II never got past prototyping and never was produced.
Development and production
The early motivation for improving the Panther tank came from the concern of Adolf Hitler and others who believed that it lacked sufficient armour. Hitler had already insisted on an increase in its armour once, early in the design of the original Panther in 1942. Discussions involving Hitler in January 1943 called for further increased armour; initially referred to as Panther 2, it became the Panther II after April 1943.
There would have been the usual tank crew consisting of 5 crew members: the driver, commander, gunner, loader and radio operator.
Following the decision not to go ahead with starting production of it, the concepts and ideas were then utilised for the design of the E-50 Standardpanzer project.
Armour
This upgrade to the Panther tank increased the thickness of the glacis plate to 100 mm (3.9 in), the side hull armour to 60 mm (2.4 in), and the armour on the top hull to 30 mm (1.2 in). Production of the Panther II was slated to begin in September 1943.
Much of the Panther II's design was taken from the Tiger tank. On 10 February 1943, Dr. Wiebecke (chief design engineer for M.A.N.) suggested thoroughly redesigning the Panther II and incorporating Tiger components such as the steering gear, final drives, the suspension system and turret based on Eastern Front experiences. The total weight would have increased to more than 50 tonnes. Another meeting on 17 February 1943 focused on sharing and standardising parts between the Tiger II and the Panther II, such as the transmission, all-steel 80 centimetre diameter road-wheels that only overlapped (as on the Tiger II) and not interleaved (as the original 'Schachtellaufwerk' road-wheel system used) and running gear.
Drawings from 1943 also showed the addition of a machine gun port for the turret, with a narrow gun mantlet. Additional meetings in February 1943 began to outline the various components, including a suggestion to use the Tiger tank's 8.8 cm KwK 36 gun, or the 8.8 cm KwK 43 L/71 gun from the Tiger II. However, it was ultimately decided to continue use of the production Panther's 7.5 cm KwK 42 L/70 gun. In March 1943, MAN indicated that the first prototype would be completed by August 1943.
Turret
The Panther II was to be fitted with a new turret, the Schmalturm turret. This turret had a stereoscopic rangefinder with lenses on either side of the turret, located in spherical bulges. The turret design maximised protection by minimising the frontal surface.
Engine
A number of engines were under consideration, among them the new Maybach HL 234 fuel-injected engine (900 hp operated by an 8-speed hydraulic transmission) and the BMW 003aviation turbojet-derived, GT 101 turboshaft powerplant, planned to be of 1,150 shaft horsepower output and weighing only 450 kg (992 lb) without its transmission, only 38% of the weight of the Panther's standard Maybach HL230 V-12 gasoline fueled piston engine. The engine would have given the Panther II an increased 200 hp, which would have made it faster than its predecessor, though it was heavier.
Thus, plans to replace the original Panther design with the Panther II were already underway before the first Panther had even seen combat. But from May to June 1943 a final meeting was held at M.A.N where it was decided that production of the Panther II would cease, and work would focus on the Panther I. It is not clear if there was ever an official cancellation – this may have been because the Panther II upgrade pathway was originally started at Hitler's insistence.
This Panther II  at Ft. Knox, Kentucky, is the sole survivor. Weight increased to 57 tons and the prototype used the running gear of the King Tiger. Only 7 wheels per side were used and were staggered to enable the use of a single torsion bar. Hydraulic steering with a reinforced gear box was used. The project was abandoned and many of the advanced features such as all steel road wheels and deeply sloped armor were incorporated into the Model G Panther I in late production models. It has the Panther 1 turret.
Here's a pic of the prototype with the Panther II schmallturm, but with Panther 1 wheels.
A pic of the tank without tracks and the turret it front
The II turret
Again with the 1 turret
A drawing of the prototype
With the 1 turret
One more
This is the kit I will be building
First off the wheels. They needed some clean up
Assembled
The suspension
The back
The turret of this kit is too broad. It sticks out on the sides. There is a resin replacement for it at the right size. But I don't like resin and I didn't bother.
The gun
Look at the size of that gun compared to the turret!
Upper hull assembly
Back taped to the hull to get a snug fit
Fully built
That's it for now folks.
Next up: Painting. :banana:
Hansolo
papatika
Hungary
Re: Panther II by Dragon 1/35
Post by papatika »
Wow, you are fast! :D
Can't wait to see it all painted and weathered!
hansolo
Post by hansolo »
papatika wrote: Mon Sep 04, 2017 8:31 am Wow, you are fast! :D
Thanks.
I don't waist too much time building. :thumb2:
Hansolo
Wow! You didn't hang about with that one! :jd:
Looking forward to seeing what you've got in mind for the finished article as always! :pop:
hansolo
Post by hansolo »
Hi guys,
Started painting.
Since the Panther II never saw action, I thought it might be a nice idea to give it a color scheme that looks like base coat painting.
Not final colours.
I started of with painting the hull a rusty red to be the chipping colour. And the turret black, a different chipping colour.
Did some fading in the centers of the surfaces.
Applied the hairspray.
Wheels painted and chipped the same way.
Final colours applied and chipped.
The tracks were painted with a dark grey. Then a dark wash. A layer of pigments applied wet and then brushed off with a stiff brush.
Then several colours of pigments applied dry.
Spare tracks painted the same way but the rust effects were done with rust effects from AK. The shot is before finishing the rust effect by brushing of most of the rust effect material.
Pigments and oil stains applied to the wheels.
The lower hull. Mud and dirt done with several layers of pigments.
Grime, dirt and rust effects done with oil paints.
Some extra chipping on the turret done with the sponge method. And colour fading done with oil paints.
Tracks and wheels installed.
Spare tracks rusted.
The rear deck finished.
More wheel shots.
That's all for now folks.
Next up: some modifying and adding of stowage and stuff.
Hansolo
Quax
Greenland
Post by Quax »
:jd: not bad for a beginner :lol: any superlatives seem somewhat superlative :clap:
A mess as usual...
hansolo
Post by hansolo »
Quax wrote: Sat Sep 16, 2017 3:19 pm :jd: not bad for a beginner :lol: any superlatives seem somewhat superlative :clap:
:lol: thanks Paul! :bow::
Hansolo
gaz45
Post by gaz45 »
Great job there mate
hansolo
Post by hansolo »
gaz45 wrote: Tue Sep 26, 2017 11:46 am Great job there mate
Thanks Gaz!
Hansolo
xSCAR45
Post by xSCAR45 »
Very impressive! :clap:
Love the weathering on this one.
hansolo
Post by hansolo »
xSCAR45 wrote: Tue Sep 26, 2017 4:44 pm Very impressive! :clap:
Thank you, xSCAR45! Appreciate it!
Hansolo
hansolo
Update
Post by hansolo »
Hi guys,
Some more progress:
I wanted to dress my Panther II up a bit.
I started of by making a little bucket from the template that I have used several times already for scratch building buckets.
I lay this cardboard template over a piece of ps plate and draw the outline on the ps.
I then cut it out and bend the piece over a paintbrush grip. Then glue it together and glue the bottom to it.
Drill 2 little holes in the side. Bend a piece of wire in the right curve.
And attach.
I paint it with grey and weather it with some pigments.
Et voila, une bucket!
Further stowage: A helmet, an MG and some tarps/blankets made from milliput and yarn.
Here's a shot of the back weathered with oil paint. My first attempt to 'micro speckling' as Michael Rinaldi calls it (also with oil paint).
The finished engine deck. Added some oil stains.
The stowage with added water can and jerrycan. The bucket hanging from the side.
I cut open one of the stowage bins and put some stuff in it. For added interest.
Next up: Final reveals!!
Hansolo
haxorb
Post by haxorb »
I just love it.
hansolo
Post by hansolo »
haxorb wrote: Tue Sep 26, 2017 8:26 pm I just love it.
Glad you like it!
Hansolo
Absolutely stunning work as always mate. Details just keep jumping out like the wood grain on the jacking block.
:bow::
hansolo
Post by hansolo »
Tomcat64 wrote: Wed Sep 27, 2017 9:13 am Absolutely stunning work as always mate. Details just keep jumping out like the wood grain on the jacking block.
:bow::
Thanks Tomcat! :th:
Hansolo
papatika
Hungary
Post by papatika »
Awesome stuff! I planned to build a Panther G for this GB, but seeing yours... I have to search something else... ;)
Great Job, Well Done! :clap:
hansolo
Post by hansolo »
papatika wrote: Wed Sep 27, 2017 10:52 am Awesome stuff! I planned to build a Panther G for this GB, but seeing yours... I have to search something else... ;)
Of course not. Please build the Panther II.
I really wanna see how yours turns out.
Use another painting scheme and dress it up in your style!
And keep me in the loop. Looking forward to it! :th:
Hansolo
SergioSolo
Post by SergioSolo »
Looks beautiful! Amazing attention to detail :clap:
hansolo
Post by hansolo »
SergioSolo wrote: Thu Sep 28, 2017 4:00 pm Looks beautiful! Amazing attention to detail :clap:
Thanks, Solo brother!
Hansolo
hansolo
Final Update!
Post by hansolo »
Hi guys,
Check out my final reveals here: viewtopic.php?f=630&t=23481&p=292239#p292239
Hansolo
Major General
Major General
Absolutely stunning work mate.
What method did you use to chip the hull and turret back to the red and black base colours?
hansolo
Post by hansolo »
Stokesy44 wrote: Tue Oct 10, 2017 11:19 am Absolutely stunning work mate.
I used the good ol' hairspray technique. And Tamiya paints are the best for this. :thumb1:
Hansolo
